Author Topic: Props for RTTL  (Read 1904 times)
Billyruffian
Props for RTTL
« on: January 28, 2011, 03:39:57 pm »
Hi all I need some help / advice with regard to propellers please.
With a twin prop boat as the RTTL that I have started, is it best to have 1 x left hand and 1 x right hand prop and do I wire the motors so that they are both turning in the same direction or opposite each other?
Thanks for your valuable help.
Cyril
Re: Props for RTTL
« Reply #1 on: January 28, 2011, 03:44:51 pm »
If you have a left handed prop and a right handed prop with the motors running in the same direction your boat will only go in circles.
Motors need to run in opposite directions. :-))
Use left and right props.
Billyruffian
Re: Props for RTTL
« Reply #2 on: January 28, 2011, 03:50:32 pm »
Thanks Dicky all sorted - that's this weekend now sorted.
Your help was very much appreciated.
cyril
Re: Props for RTTL
« Reply #3 on: January 29, 2011, 09:58:43 am »
hi ya there Cyril
Props which I used on the RTTL build are borth left-handed turning anti-clockwise, as you look at them from the back and they are of a 35mm diameter - brass - 3 bladers.
That, is in keeping with the original vessel - scale sized props and same handed.   However, the power supply Mtroniks 600s, runnin on 8.4 NiCads.
Hope this is of some help.
aye
john
Page created in 0.104 seconds with 21 queries.
