Simon,
The indespensable aid for every IC owner - cut down fishing rod, reel, 50 yds of 15 lb line and a tennis ball
Glad you got it sorted. Always good to test the seal on the radio box
Mart's video looks good. We'll have to get him in competitions
Just to show - you're never too old to be stupid - I tested the geared 3.5, no problems, tried a CMB pipe, good results.
Swapped 3.5 boat on stand for 7.5
- would it h**l as start.
Nearly an hour!
Tried everything, eventually thought 'sod it' and was just packing up when I noticed the starter connected to the battery, red to neg (I should point out that I connect the starter in reverse for the geared motor so that I can still use the starter the 'right way round') - I had forgotten to swap the clips over for the straight drive and had been trying to start it in REVERSE
Swapped the leads over and away it when first time!! - doh!
Danny
