In the interests of my sanity, I decided that I needed something else to work on while procrastinating about the hard bits on my ULCC build.
I had been eyeing up the Hibbard ever since I purchased the magazine it was in back in October 2002 - actually, due to my location, I probably got it in November of December 2002...
Anyway, for those of you not familiar with the Hibbard, she is a modern semi-scale (stand-off scale) guided missile destroyer based loosely on the Arleigh-Burke class ships of the US Navy at 1:144 or so. That's what I recall from the article Mr Guest wrote to accompany the plan - my apologies to him if I have anything wrong.
Googling the Hibbard finds the plan but not any actual builds - well, that my Googling could find anyway... I looked at several plans from MB and MMI and eventually chose the Hibbard over the Nouveau (a modern commuter launch) in the April 2002 MMI as I wasn't sure I could find the rights types of wood here in dear old NZ...
Anyway, I studied the Hibbard, Googled for images of guided missile destroyers and considered altering the superstructure of the Hibbard, but have - I think - decided not to do that as I would run the risk of ruining the balance the Mr Guest achieves in his models. By which I mean the look the model, not inducing a list or something...
The next requirement was balsa - what a mission! Hard to find model shops in Auckland that supply a range of sizes and the price! 100 x 6 x 915 (or 4 x 1/4 x 36 depending on where you grew up) could be up to $11 per sheet! That's highway robbery in anyone's language! Eventually I found an online only supplier in NZ (based in Whangarei for any curious Kiwi's out there - Atomic Hobby Supplies) who had imported balsa supplies (imported cut to size rather than cut in NZ) and got 5 sheets at 100 x 6 and 5 at 100 x 5 delivered for $60. From a local hobby shop, 5 sheets was going to cost a minimum of $45 plus delivery. And lets not mention grades of balsa - there's only one grade here and it's what's in stock - none of this soft, medium or hard malarky! I think the stuff I have is somewhere between soft and medium - it's definitely not hard...
Anyway a prop shaft, prop and various other bits were required. I toyed for several days with ordering all the bits from Cornwall Model Boats - it looked like I could get all that I needed delivered for less than $100NZ. Eventually I decided to support my LHS (or nearly the LHS) and bought some bits from them. A 300mm proptube and shaft assembly, a prop and one half of a universal coupling for about $45NZ. Hmm - cheaper from the UK I think as the CMB order would have included 2 props, 2 shafts, 2 complete universal coupling and a Graupner 600 series 7.2v Eco motor (as specified by the estimable Mr Guest)...
Am I being a bit wordy? Probably so - so here's a pic or two:
Hull pieces cut as per the plan (more or less anyway). And all while epoxy was setting on the ULCC (yeah right...)
Some pieces getting stuck together:
Some more pieces stuck on:
At this point it seemed to me that the hull bottom had a bit of a twist to it. "xxxxx" said I. After a few days of applying weights to no effect, I settled for a bit of steam from a boiling jug, some more weights and going away for a family birthday for three days. Oh - and ensuring that I had as flat a work bench as I could - by getting piece of 18mm MDF to use. The result is a hull so close to flat that it's close enough to work with. Probably the cheap balsa - haha!
So I stuck the deck on:
Anyway, that's almost where I'm up to, I'll get up to date in another post some other time.
(ROFLMAO - I've been automatically edited! I couldn't figure out how those X's got in place during the preview. I promise to try not to use NZ English again - but if you see X's you will know I failed
