Hi there Captin Jimmy
I myself am unsure of the method you are using to plank the hull on your model. There are 2 methods you could use - for double planking - they are
Double plank Carvel - this is where the planks run from the stern to the stem parallel with the keel up to the gunnel and they are butt jointed (edge to edge). This layer of planking is then corrected by sanding and filling to remove any hollows or bumps. Then, the 2nd layer is applied over the top ensuring that the joints between the planks do not coincide with the plank edge joints of the first set of planks. The outer layer of planks can then be sanded and finished with various grades of sand paper and sealed with either polyester resin coating or an epoxy. There is no real need to add matting or a woven roven in this layer, because all we need from the finishing layer is to create a barrier to create a suitable barrier to prevent moisture from reaching the planking. The strenth is already built in to the structure by the planking method you have used and it is a reasonably strong and tough structure.
Double diagonal - follows the same pattern as double plank carvel - but the planks run from the keel at a 45 degree angle to the chine - from stem to stern and also run from the chine to the gunnel at the opposite 45 degree angle - for your first layer of planking. This again, once again completed, is sanded and filled to correct any mis-shapes.
Then the outer layer of planking is applied in the opposite direction on top of the first layer of planks.
When this planking procedure is completed it can be finished off in either of the above methods.
Of the two methods of planking the double diagonal one is a stronger one because it becomes a form of plywood as the grain of the planks run at 90 degrees to each other.
Therefore, as mentioned above, it is the stronger one - so only requires the minimum of barrier between the water and the planking and therefore it would be suggested that an epoxy finishing resin would be used.
The main thing is though to seal the inside of the hull as well; with either a polyester or an epoxy resin as this stabilises the planking and structure and prevents moisure entering the planking causing it to swell and break away from the outer layer.
For a better view of this have a look at the 63 ft Whaleback Build on this forum - this build does use a very fine layer of tissue matting - along with polyester resin and also if you look in the warships section at the Vosper RTTL 2751 build, this only uses epoxy on the outside.
These are eventually painted, but, you will be able to see the standard of finish achieved by polishing with wet'n'dry.
Hope this helps
http://www.modelboatmayhem.co.uk/forum/index.php?topic=9758.0http://www.modelboatmayhem.co.uk/forum/index.php?topic=20758.0aye
john
