Try contacting the company directly and see if they will supply the plans that you would need. You will need side profiles and main deck to the highest deck level drawings and also you will need hull lines/ faired lines to help you build the hull. I have done this a few times with some of the AHT style tugs that are out there. So far it has resulted in me getting about seven different design tugs.
Duane
