I've just had a bit of a breakthrough with suppressing a Taycol that might interest other users of this motor....
After a disassembly and clean, I found one of my Taycols running roughly, and sparking a lot. This was in spite of my paying particular attention to the brushes and commutator, cleaning them both with meths. There was also a huge increase in RF interference.
Eventually I disassembled it again and looked at the commutator surface, which was pitted badly. The Taycol brushes are copper, and the commutator is brass. The sparks between the two were welding the two surfaces together. Then I recalled the operating instructions for the motor, which advise oiling the brushes at 15 min intervals. I did this, and the motor returned to its normal self....
Oil should usually be kept well clear of brushgear, especially carbon brushes, which will be clogged up in no time. But metal-to-metal brushes have a very low contact resistance, and can cope with a thin film of oil. In fact, the oil film seems to quench the incipient sparks, and limit the RF interference. Hence the operating instructions...
Taycols are famous for ruining radio reception. I wonder how much this is due to operators keeping the brushgear clean, as they should for most motors, rather than obeying the Taycol instructions and giving the brushgear a lavish squirt of oil?
