Pages: 1 [2] 3   Go Down
Author Topic: Which 2.4Ghz Radio  (Read 20420 times)
Re: Which 2.4Ghz Radio
« Reply #25 on: March 10, 2011, 09:47:40 pm »
I would remind you Colin, that when this problem first came up I suggested you try another different Tx and Rx and see if the P80 worked with them.
You obviously didnt change the Rx but just the Tx. Pity it would have saved a lot of time. :((
shimsham
« Reply #26 on: March 10, 2011, 09:52:28 pm »
Dicky. When you say change the Rx do mean change for a identical one or a different brand.
shimsham
« Reply #27 on: March 10, 2011, 10:06:21 pm »
Dicky. I dont know where the problem lies is it Dx7 or the that particular esc i dont think Dave is 100% certain,but one things for certain i wont be going down this route again i can assure of that, i am not sure whether its worth all the aggro thats involved,the part what i dont understand is no problems with the P93 but problems with the P80 possibly with the exception of Dave i dont think anyone on this forum knows where the problem lies.
ACTion
« Reply #28 on: March 10, 2011, 11:11:51 pm »
There is no problem with P80. We have sold hundreds of them and this is the only instance of this which I can recall. Draw your own conclusions but let's have no more of this ill-informed speculation, please.
DM
PMK
« Reply #29 on: March 11, 2011, 05:16:44 am »
PMK. I think you have got it slighty wrong,Dave at Action tested my RX [MR3000]...
Ah, in which case I owe you an apology. In fact, if I had taken the time to read your post #14 properly in the first place, then I would have realised that you'd said "Rx" and not "Tx". I stand corrected.
Also, you may have detected a slight bias towards Futaba equipment on my part (especially the build quality on their FF7 and FF9 radios onwards). In other words (and please don't consider this as a put-down towards the DX7 in any way), some of the more modern Futaba sets employ nice Molex-type connections throughout, whereas Spectrum simply solder their off-board connections to pads on the PCB. As you may know, some earlier Futaba sets use the same method, which, I have found on more than one occasion, the off-board connection have sometimes became loose, or simply disconnected altogether. And no, it's not a real major issue - it's simply more of an annoyance. But one gets none of these 'problems' with Molex connections.
Although, none of the above jive really offers any explanation as to why the P80 should suffer a certain hiccup with DX7 sets. The DX7 which I tested yesterday did have a somewhat lower pulse signal on the throttle channel (and no, I have no idea why either), which initially led me to think was the root of the problem. The P80 worked perfectly on all the other channels once the 2-second autoset feature had kicked in... it even worked fine as soon as I routed the throttle channel through a simple pulse booster.
The only explanation I can offer is that the owner of the DX7 had programmed a mix with one of the toggle switches in order to work as a throttle 'kill' switch for his glowplug engine. Maybe some sort of cock-up lain within the program mix itself. Who knows?... I'm just clutching at straws. But at least I ascertained that the fault was nothing to do with the ESC itself.
« Reply #30 on: March 11, 2011, 05:50:11 am »
Another vote for Futaba here
Although I have just bought a Flysky 9x for a project Im working on
shimsham
« Reply #31 on: March 11, 2011, 08:37:58 am »
PMK.  TXs are alot like cars ie Ford - Vauxhall you pay your money and you take your choice.I will put my hand up and say i am not to clued up on the electronics of this hobby,but what i will say i have had this Dx7 for 3 years now and i bought it brand new and i can honestly say i have never had any problems with the Dx7  i flew planes /helis previously before going into boats.
PMK
« Reply #32 on: March 11, 2011, 08:47:24 am »
Agreed. O0
tmbc
« Reply #33 on: April 01, 2011, 07:54:01 am »
ive had a futaba 6ex ! good radio but pain on the menu's ! i also have a futaba 7c brilliant no problems menu better and more accessable used it on 1/10th car no problems with speed contoller ! sorry aint got electric boat ! but i use it in my gas boat too no problems either
futaba 7c all the way !
Martin13
« Reply #34 on: April 01, 2011, 11:59:49 pm »
I myself have owned/used the DX7 - worked perfectly with each and every peripheral that I threw at it. My only two nags were the way in which the Spektrum folk employ their somewhat annoying binding system, and also that it was pretty limited when it came to programming the Tx for model planes. Unfortunately I never owned a P80 while I owned the DX7, so cannot really comment about that particular idiosyncrasy.
Pete, your input please.
6 months ago I purchased a DX7 full kit only to receive another as a gift a short time later. My intention was to use the DX7 with my boats but mainly on gliders as I have several (slope and thermal) and also hope to have some electric gliders in the future. I liked the idea that I could program each model into the computer with various mixing available as some models require at least 6 channels....
Many years ago I only used Futaba and had a 7 channel 36MHz unit (for Oz) and the unit operated flawlessly.
You say that you are not 100 % happy with the DX7 and prefer your Futaba units. Although we have never met (for obvious reasons) I have the utmost respect for your opinion and knowledge of electronics along with designing and constructing various gizmo's.
Can you outline/detail the problems you have experienced with the Throttle channel for the DX7 and is this likely to impact on my applications (crashing can be expensive) - also any other hiccups you may have experienced.
I am currently considering selling my 2 x DX7's and purchasing a 2.4 Gig Futaba unit instead but am now unfamiliar with the Futaba model designations etc......mind you, it's only a thought at the moment....
Martin doon under - considering all options/opinions
PMK
« Reply #35 on: April 02, 2011, 11:33:45 pm »
Although we have never met (for obvious reasons) I have the utmost respect for your opinion and knowledge of electronics...
You old smooth talker you!
Where to begin. Do you have a spare couple of days?...
Spektrum versus Futaba. We're treading on thin ice here because no matter how much thought has gone into wording my own opinions, the problem of upsetting owners of certain R/C equipment will always be there; no person likes to hear that their particular brand of Tx is inferior to other brands, so my opinion is simply just that - an opinion, and not necessarily the same opinions of other folk. All I can offer is an unbiased view of the good points, along with the bad points, of R/C equipment and leave it for yourself and others to make up their own minds.
First off, you mentioned gliders. Straight away you have caught me on the hop because I have never programmed any radio for glider operation. I know that both Spektrum and Futaba encorporate programming parameters especially for gliders, but it's not something that I ever had cause to use. My one and only experience with electric gliders was not exactly fruitful, so I ended up dumping the glider on fellow forum member Bob (Young at 60). I'd mentioned in a previous post that I owned a DX7 for a while, but I didn't have it long enough to fully delve into the menus for glider setups. For all I know it may well indeed handle that particular aspect with flying colours. On the other hand, I can tell you that the Futaba 9C Super does in fact cater very well for every parameter covering just about every type of glider available.
Secondly, you might consider the build quality of each radio. In my opinion this is where the Futaba leaves the Spektrum standing. Again, I've already mentioned Molex connections throughout on the Futaba 7C and 9C radios onwards, whereas the Spekky Tx has all of its off-board wiring connections simply soldered-tacked to copper pads on the main circuit board. Futaba also goes one better by using separate PCBs for all their toggle switches and rotary pots, again each PCB interconnected to the main PCB via sturdy Molex connectors. Spektrum have opted to simply solder any off-board wires directly to the contacts of the toggle switches, etc... and not even as much as one piece of heatshrink tubing in sight.
Gimbals: Futaba have very cleverly designed a simple plate which is attached on the rear of the throttle gimbal mechanism. The idea being that you can quickly and easily swap the plate on to the other gimbal should you prefer to have the ratchet throttle on the right-hand side. There is no need to fuss around with installing springs and all the usual hassle associated with a self-centering stick because the spring is already there. The plastic plate simply pushes the self-centering spring away from the gimbal, while at the same time a 'click' ratchet comes into play. It's hard to describe without actually looking at the design, but all in all it's a very clever move on Futaba's part.
The gimbals on the Specktrum do not move as far as the Futaba gimbals from their centre positions. In effect, the limited movement of the Spektrum gimbals give an overall less movement on the servo horn. You can dial an extra bit of servo throw from the programming menu, but from my own point of view I'd sooner have the gimbal mechanically travel farther than it actually does, and then have the option to reduce the amount of servo throw via the menu system if necessary.
2.4GHz: Futaba employ their FASST system, while Spektrum employ their DSM system. Now without getting too deep into the technicalities, the FASST system (again just my own personal opinion) is far superior in every way. I still feel that Spektrum's Spread Technology system is very clever stuff, but also feel that they rushed their ideas before fully putting the system through its paces. I'll probably get shot down in flames for saying this, but I've lost count of the number of complaints whereby Specktrum owners have suddenly lost the binding between the Tx and the receiver(s). Many Spektrum owners have also reported that the stored parameters of each model have suddenly been erased from the memory - for no apparent reason at all. And, of course, there is that somewhat strange case of the lower amplitude pulse on the throttle channel (see later).
Of course, Futaba equipment has not been without a few teething problems as well, but in all in all I can honestly say that of the three Futaba system failures which I've witnessed, two of those have been due to pilot error (even though they won't admit it), and the third error was caused by the careless attitude of the owner; he had stored his model and the battery pack in a cold, damp shed throughout the Winter, which eventually caused the so-called dreaded 'black wire syndrome' between the battery switch and the receiver. It was a crash just waiting to happen.
Question time: So on the strength of this...
Would I install Spektrum equipment in a model airframe? Answer: No.
Would I install Spektrum equipment in a fast nitro boat? Answer: No.
Would I install Spektrum equipment in a run-of-the-mill boat for simple R/C use? Answer: Yes - probably. But I would be constantly fretting about losing the binding, or model memory suddenly going belly-up.
So you're probably wondering if I'm biased towards Futaba equipment, to which the answer is yes, absolutely, without doubt. Besides, in the case of the 9C and 9C super, one has the option to delve into the so-called Service Menus, and from therein one can do all sorts of customised tricks. (Futaba does not make this knowledge freely available, probably because it's likely one could frazzle the main microprocessor).
Scroll up the page to reply #9 from 6705russel. Grok the first photo. Do you see the small badge in the top-centre of the radio just above the middle rotary pot marked "CAMPac"?  Located behind that badge are 6 wire connectors. With a bit of jiggery-pokery it is possible to talk with the microprocessor and you'll get to see several pages on the LCD which are normally reserved for Futaba's service engineers only. From there you can do all sorts of nifty things. For instance, you can swap all the 2-position toggle switches for 3-position toggle switches. Just that one simple modification alone can add a zillion more options in the user menus. The clever thing is that all the hard work is already done for you - the software is already tucked away in the processor - you simpy have to tell it what's what and it happily does all the tricky work itself.
Finally, grok the attached image. What you are seeing there is the signal pulse train taken from the trainer socket on the rear of the radio. Look at the line of blips on the centre line of the graticule - there are 9 in total. The first blip is the start of the usual 20 milliseconds framerate - the so-called sync signal, followed by eight more blips. If the oscilloscope were wider you would see the same sync blip 20mS later.
Now look at the 8 pulses shown beneath the blips on the graticule centre line. The reason they are beneath the centre line is because Futaba employ their standard negative shift (otherwise known as 'low shift'). Other makes of transmitters sometimes employ a 'high shift', in which case the eight channel pulses would be ABOVE the row of blips on the centre line. Each of these pulse are the 8 channels of the 9C, all roughly set to 1.5 milliseconds length. The first pulse from the left-hand side is Channel 1 - the Elevator pulse. Channel 2 is the Aileron pulse, channel 3 is the throttle pulse, channel 4 is the rudder pulse and channels 5 through 8 are the auxillary channels.
The only reason for all this bumph is to let you see that the voltage (or height) of each pulse from the centre line are all the same amplitude (the same voltage), which is exactly how it should be. But, and here's the spooky part, when I 'scoped the pulse train of a DX7 recently I noticed that the amplitude of the throttle pulse was much lower than all the other pulses. Why? Well, your guess is as good as mine. Perhaps, as I said in the previous post, it might be something to do with how the owner had programmed a toggle switch on the throttle channel to work as a 'kill' switch for his glow engine. Or perhaps the radio itself was one of those 'Friday afternoon' jobs, perhaps a one-off dodgy transmitter. Who knows? All I know is that it didn't look too encouraging. I programmed the same scenario into the 9C, yet the throttle pulse remained at the same amplitude as the other 7 pulses.
You mentioned that you are considering selling your DX7's. Please don't do that on my say-so. If you're happy with your Spektrum gear, and it works for you, then by all means give it the tender loving care that you think it deserves. After all, there are many hundreds of Spektrum owners on this forum alone and each one are perfectly happy with them.
David Shaw
« Reply #36 on: April 03, 2011, 08:02:11 am »
From my experience , I have converted both my Futaba 3EGX and Graupner MC!9 over to Jeti 2.4 GHZ. So has one of my friends who has the same Tx's. Another friend has just converted his Multiplex Royale over to the Jeti 2.4Ghz. In all models both scale and very fast fast electric we have never had any problems. With all the data sensors you can get, know live what the voltage and amps we are drawing. What temp the motors and batteries are at and know with the release last year of a GPS module what speed we are running at. Although once we have set up the boat we only run with a temp sensor on the Lipo's.
So from personnel experience I highly recommend the Jeti Duplex 2.4 system.
Hope this has not confused you more.
David
shimsham
« Reply #37 on: April 03, 2011, 08:35:02 am »
PMk.   "WOW" what a reply, i take it you dont like Spektrum that is fair enough,but 2 years ago i flew at a club where 80% of the members used Spektrums mainly Dx5/6 but i have never seen any binding problems with exception of one,when father & son bought a brand new Dx6i and they lost the plane for incorrect binding,possibly agree with you and many others on here with spektrum & boats dont mix very well,but as far as planes/helis/gliders they are brilliant and if you were to go to some of your local flying clubs you will possibly see speks out number futaba,cant see see you getting a job at Horizon Hobby :((
PMK
« Reply #38 on: April 03, 2011, 01:00:56 pm »
Fair comment. BUT...
If you care to re-read the 2nd paragraph which says "We're treading on thin ice here...", and then re-read the very last paragraph also, then you might perhaps notice that not once did I ever say that I don't like Spektrum. Instead I merely offered an opinion of two very popular radio systems. That's all it was - just an opinion.
I have used a DX7 in model planes and model boats, and yes, I did experience a couple of odd glitches. Nothing serious but enough to make me feel uneasy. On the other hand, under the exact same conditions, using various other makes and models of radio equipment installed in the same models, I never experienced even as much as one tiny hiccup. It's not that I'm bad-mouthing Spektrum - just merely pointing out a few facts is all.
Besides, unless you yourself have actually used the Futaba 7C or their 9C radios yourself, then perhaps you'll appreciate that the programming menus and user options are far superior to those of the Spektrum. Like I said previously, the Spektrum menus and features are at best limited. It's a very fine piece of kit, it does what it says on the box, but would be even finer if it instilled more confidence in its build quality and reliability.
I'm just glad to hear that you have had no problems with your particluar system. But you have to admit that your own personal opions are a tad more biased than mine on account that you have not had the chance to compare your Spektrum to any other other make/model.
shimsham
« Reply #39 on: April 03, 2011, 01:19:27 pm »
It was only meant as a lighthearted reply,but as you well know i have had problems with ESCs and the Dx7 personally if i was going to buy another upmarket Tx and stay with boats it would no doubt be a Futaba and yes you are correct i have never owned a futaba,i was only pointing out that when FLYING i have not met anyone yet who as had problems with the any model Speks,but there is people who are highly critical of radios they dont have and never used,i have never criticised Futaba because i have never used owned one and as i have said before you pay your money and you take your choice,and yes i did real your thread all through and it was a terrific write up.
PMK
« Reply #40 on: April 03, 2011, 01:24:05 pm »
"It was only meant as a lighthearted reply..."
Oops! My bad - I'd obviously  taken the comment the wrong way. I stand corrected once again.
shimsham
« Reply #41 on: April 03, 2011, 01:31:12 pm »
 " It was not meant to upset you"
Youngat65
« Reply #42 on: April 03, 2011, 01:45:28 pm »
Take another pill PMK trust you are Ok may get to your part of the world this year  :-))
                                          All the best Bob
emspaul
« Reply #43 on: April 03, 2011, 11:48:02 pm »
I am having the same problem with the DX6i ,
No throttle response at all ,rebind ,rebind and nothing.
Just picked up the Futaba 6EX fsst system.
I will be testing it this coming weekend .
As far as Horizons service it has gone from great to mediocre as of late.
Just my 2 bitts .
emspaul
« Reply #44 on: April 05, 2011, 01:51:18 am »
I received a p.m. from Collin.
And it made me start thinking about this problem that we all seem to be having.
So here are a couple of questions for all out there.
1 For the folks having this problem, How are you powering your RX ?
Are you running your RX off of the BEC?
Or are you using a power pack just to power the RX?
2 For the folks with no problems,
How are you setting up your RX?
I have swapped out both of the ESC`s and had the same issue`s with 4 differant RX`s.
I have a lot of money tied up and can not use it.
« Reply #45 on: April 05, 2011, 06:15:11 am »
Ive found that running a seperate RX battery pack seems to be far better (read stable and less glitching) than running off the BEC on most speed controllers I own
emspaul
« Reply #46 on: April 05, 2011, 11:39:18 am »
I am not getting any glitching ,just dead stick. :-))
« Reply #47 on: April 05, 2011, 11:55:15 am »
Depending on the ESC in question, is the BEC actually enabled?  Very silly question I know but worth asking  ok2
HS93 (RIP)
  • I cannot spell , tough
« Reply #48 on: April 05, 2011, 12:34:17 pm »
do you run the same voltage as the tx holder would have been, is it just extra M-Amps
emspaul
« Reply #49 on: April 05, 2011, 01:17:41 pm »
I have tried both ways with the same results . :-))
And ,no it is a bad question.
Pages: 1 [2] 3   Go Up
Page created in 0.028 seconds with 22 queries.
