Author Topic: Cutting wires, DON'T!  (Read 2383 times)
wartsilaone
« on: March 09, 2011, 07:41:50 PM »
Don't cut the wires your expensive BEC type ESCs. Buy a short servo extention for a couple of quid and cut the wires on them. This will future proof them should you wish to use them in another model.
Roadrunner
Re: Cutting wires, DON'T!
« Reply #1 on: March 09, 2011, 08:10:55 PM »
Not thats its not a bad tip, but why would you cut the BEC/data leads on an esc in the first place? if you need to have more reach on the lead use a standard servo extension cable.
Only time i see that its worth cutting the lead down is if there is a break in the cable and you have managed to locate it to fix..
If your trying to stop the BEC function just un-clip the central wire (yellow/orange) from the plug and wrap it with some black tape or heat shrink.
wartsilaone
« Reply #2 on: March 09, 2011, 08:18:02 PM »
I didn't want to do anything with the ESCs as this may void the warrenty
« Reply #3 on: March 09, 2011, 09:30:44 PM »
Centre wire is normally red  :-))
ACTion
« Reply #4 on: March 09, 2011, 10:29:51 PM »
brianc
« Reply #5 on: March 09, 2011, 10:58:40 PM »
If your using two speed controllers you need to disable one of the BECS :-))
wartsilaone
« Reply #6 on: March 09, 2011, 11:21:24 PM »
You,re not getting the point i was trying to make which is, Why ruin something that may cost as much as 30 when for 2 more you can have what is effectively an adapter and you will have more options when configuring your radio setup.
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #7 on: March 09, 2011, 11:37:43 PM »
Or get a marine ESC that has a jumper that disables the BEC.
wartsilaone
« Reply #8 on: March 10, 2011, 12:08:43 AM »
Yes it does depend on the make. My Mtronics ESCs don't have a switch that disables the BEC function. You get what you pay for!
Peter
« Reply #9 on: March 10, 2011, 03:00:04 AM »
Why can't a good, simple piece of advice be accepted for what it is?
I agree with Wartsilaone on this method, but at the end of he day, it is only another option that others may not have thought of.
Peter
Umi_Ryuzuki
« Reply #10 on: March 10, 2011, 03:34:05 AM »
The first thing I do to most of my ESC, is cut the power switch off, and solder a plug on the ends.
This way, the BEC is disconnected if need be, however, I usually solder a long wire onto the switch, then
mount it somewhere on deck and plug it back in.  The wires have to be cut to put plug, and then run a
lead to where I want my switch anyway.
As for extending the receiver lead, it is cheaper to clip it and solder in an extra length of wire than to buy
a servo extension lead for $6.00...
Peter
« Reply #11 on: March 10, 2011, 03:48:11 AM »
I don't think that the original point was to extend the lead.
It was simply a suggestion of method of disabling the BEC without affecting the original ESC wiring.
Peter
RaaArtyGunner
« Reply #12 on: March 10, 2011, 04:00:49 AM »
Peter
O0 O0 O0
portside II
  • tugs at rest
« Reply #13 on: March 10, 2011, 10:30:41 AM »
I use a tiny screw driver (just like Dave show's on his link) to remove the center wire from the plug , it can then be replaced if needed , even the manufacturers wont notice what you have done.
As for the servo extention leads , yes they are a good idea but where are you guys buying them from 2.00/ $6.00  :o ,
the last lot i bought from the bay worked out at 20p each , and i have not had one out of the batch of 50 fail .
daz
I like to build my boats to play with, not to just look pretty,so they dont !
