Some old RXs have a socket rather than a set of pins, but are in the same order as modern equipment. The servos for these had pinned plugs, rather than line sockets as the modern gear. Conversion is a simple matter of creating pins by using short lengths of appropriate thickness wire. As long as the +, -, and signal wires turn up in the right respective places, no problem.
Referring to a pararell setup -
"This type of twin motor wiring setup (series) will yield high speeds but short runtime. This setup will also most likely blow your motors, esc or bake your batteries! On the above wiring setup each motor will get to use the full voltage of the battery pack".
Referring to a series setup -
"This type of twin motor wiring setup is the most widely used in fast electrics. A series set of motors properly setup will be fast and yield long runtimes. On the above wiring setup each motor will see half the battery pack voltage."
What does everyone think about the above comments?
This might be correct in a very particular context, but generally, the statements are totally incorrect.
Run on 12 volts (two 6v batteries in series), the 12 volt motors will each give their intended power if connected in parallel. They will each draw their full current to achieve this, and the prop(s) will determine this. If one ESC is used, it will need to be able to handle the full current, lots of threads covering this.
In series, each has effectively a 6 volt supply, half the voltage, half the current, therefore, one quarter the power each, and performance to match. If one of the motors is stalled, its resistance drops greatly, and the other gets full power, gets hotter, and has a good chance of turning the boat in circles.
Connecting one motor in reverse is the way to get counter rotating, but remember that this needs a left hand prop and a right hand one.
