Author Topic: Maxwell Hemmens Canton  (Read 3714 times)
unicorn
« on: March 30, 2011, 03:07:14 pm »
                  Hi    ---   just purchased The Canton  -- a Maxwell Hemmens twin 3/8marine engine and boiler  --  repaired the steam feed
         pipe to the engine and then fired her up and she ran like the proverbial Sewing Machine with no problems .The next step was to
         pressure test the boiler and here`s the problem I can`t  determine what the threads for the safety valve or steam outlet were,
         could any Canton user`s tell me what they are and where I might purchase some blanks to adapt for pressure testing, any hints on
         running this plant would be more than welcome.
                        thanks in advance
                                                       unicorn
pipercub1772
Re: Maxwell Hemmens Canton
« Reply #1 on: March 30, 2011, 05:48:36 pm »
the engine you have is a caton not canton, try John hemmens at steamengines.co.uk he should have all the information you want
Meyer
Re: Maxwell Hemmens Caton
« Reply #2 on: June 13, 2011, 07:03:22 pm »
Hi, Max Hemmens Caton engine threads, are just slightly smaller that to days std of 1/4 by 40 tpi, don't try and force a todays std union nut, or you will srip the threads,!!!
however I do have a caton steam valve with one union, that is available , if you want it, ( no charge) for a member , Roy: [email protected].
Meyer
« Reply #3 on: June 13, 2011, 07:42:46 pm »
Hi, I have just checked my old books, and Max Hemmens Caton engine, union threads are A/F and not to day sstd ME,  hope this helps Roy
Page created in 0.327 seconds with 17 queries.
