Author Topic: Twin motor connections  (Read 3311 times)
Terry
« on: March 30, 2011, 04:54:38 pm »
Can anyone help please with a wiring diagram/instructions for a two-motor set-up.
The motors are brushles outrunners - Overlander T3548/5, 770 Watt, 890 revs/volt;  two esc's, Fusion 60 Amp FS-HWK60; Spektrum DX& transmitter; Spektrum receiver AR6200.
The esc's have been pre- programmed for reversing.  I'm not too good with electronics, and don't want to blow up loads of expensive kit!
Terry
barriew
Re: Twin motor connections
« Reply #1 on: March 30, 2011, 05:27:32 pm »
Assuming both motors are to be operated off the same channel, then its quite simple. Wire each motor, ESC and battery as for a single motor setup. The only difference is that you need a Y lead from the Throttle slot on the Rx. Plug each ESC into one of the ends,BUT you need to disconnect the RED lead from one ESC plug.
Barrie
Terry
« Reply #2 on: March 30, 2011, 05:39:57 pm »
Barrie
Thanks Barrie
POP
Terry]
Page created in 0.026 seconds with 17 queries.
