Author Topic: TAYCOL MOTOR  (Read 2194 times)
taximart
TAYCOL MOTOR
« on: April 14, 2011, 09:43:13 pm »
Hi everyone, I have just aquired an original Aerokits Sea Queen built in the 1950s it requires some rebuilding and it is fitted with a
Keil Kraft Taycol motor called the supermarine it has brushes and runs off 8-12volts. what I would like to know if anyone can help is what kind of speed control would it work with.Thanks . Martin.
john s 2
Re: TAYCOL MOTOR
« Reply #1 on: April 14, 2011, 10:18:15 pm »
Dodgy Geezer has set up a website for Taycol Motors.Hes done an excellent job.
http://taycol.hobby-site.com/install.html. This site should answer All your questions. You can also use the
Mayhem search facility to find out posts on Taycol. John.
taximart
Re: TAYCOL MOTOR
« Reply #2 on: April 15, 2011, 08:37:15 am »
Thanks John for your info. I went to the site and it tells me all I want to know. Regards Martin
kiwimodeller
Re: TAYCOL MOTOR
« Reply #3 on: April 15, 2011, 10:45:59 am »
I have an original Sea Queen running with a Taycol motor and modern radio control. It took a bit more effort to sort it out but it was well worth while and now you have all the info from Dodgy's website plus what is on Mayhem it should be straight forward. The main thing is to use every form of suppression known to mankind! Best of luck and dont forget to post before and after photos on here. Cheers, Ian.
Re: TAYCOL MOTOR
« Reply #4 on: April 15, 2011, 01:43:35 pm »
  Most suppressive form I've found for these is a piece of Hickory about ten inches long, let into a piece of cast steel weighing aproximately seven pounds. %) :-))
Arrow5
Re: TAYCOL MOTOR
« Reply #5 on: April 15, 2011, 01:57:19 pm »
How about a bigger swing at it ?
..well can you land on this?
