Author Topic: 40 mm BOFORS  (Read 14569 times)
colin-stevens
40 mm BOFORS
« on: May 01, 2006, 12:45:11 pm »
so here is another unfinished project. it will stand alone as it is 1/12 as i remember. the scale was decided around the size i could spin on my lathe. it was spun betwwen cenres using dogs. i had no taper on the tool, instead the chuck and motor rotated. how i never killed myself when it came out the centres.
it's built using the John Lambert plans. cost a fortune as i bought the lot.but i have no info on the inside of the gun aimers pod. so if any one can help, please do.
grumpy old XXX
colin-stevens
Re: 40 mm BOFORS
« Reply #1 on: May 01, 2006, 12:46:49 pm »
more
grumpy old XXX
colin-stevens
Re: 40 mm BOFORS
« Reply #2 on: May 01, 2006, 12:48:19 pm »
i'm bored, so here is more
grumpy old XXX
ron h
Re: 40 mm BOFORS
« Reply #3 on: May 01, 2006, 12:53:50 pm »
Very nice, sorry I can not help out. ron h
Re: 40 mm BOFORS
« Reply #4 on: May 01, 2006, 01:17:51 pm »
Hi there Colin
I dont know if this photograph is any good to you, but, you can just make out the inside of the gun aimer's pod.  This photo is of the 30mm gun, this one is on the HMS Leeds Castle - you can just make out some detail - dont know if its going to help you at all.
Aye
John E
BLUEBIRD
[Too Large - attachment deleted by admin]
colin-stevens
Re: 40 mm BOFORS
« Reply #5 on: May 01, 2006, 04:45:06 pm »
thanks but its no use, totaly different set up.
grumpy old XXX
dennisw100
Re: 40 mm BOFORS
« Reply #6 on: May 01, 2006, 09:52:34 pm »
So are you going to make a carriage for it?
Then you can take it to model fly club displays....
.....see how many you can bring down ;D
ron h
Re: 40 mm BOFORS
« Reply #7 on: May 01, 2006, 10:23:30 pm »
sweeper
  • When all else fails, read the instructions
  • Location: On the edge of reason, in the state of Confusion
Re: 40 mm BOFORS
« Reply #8 on: May 02, 2006, 12:51:50 pm »
I assume that this is the same model type as fitted to the "Ton" class sweepers and hunters? From memory Mk8?
I can remember that they had a reflector gunsight, foot pedals and a control column with handlebar type grips. There was an electrical mainswitch on the right hand side of the gunner (about level with his leg).
You could try having a look at one of the preserved ships or the inservice MCM's.
If it is of any help to you, I have drawings showing various views and details (1/48 scale) of the later Mk9 mount. May be able to furnish you with details.
colin-stevens
Re: 40 mm BOFORS
« Reply #9 on: May 03, 2006, 06:37:56 pm »
yer she is the same as what is fitted on the ton. larger version of what i for some reason best known to my alter ego as hms trent.
grumpy old XXX
Tug
Re: 40 mm BOFORS
« Reply #10 on: May 06, 2006, 07:41:57 pm »
Colin, That looks great....now if you could knock out a few in 1:32 ?  ;)  Ken
Junk is something you've kept for years and throw away three
 weeks before you need it.
freelance 1
Re: 40 mm BOFORS
« Reply #11 on: November 21, 2006, 12:17:01 am »
On surfing from page to page I found your article on the 40mm bofors an excellent topic, to the builder of the 1/12 scale a fantastic model, thanks to all, my search is not over but many thanks to all.
chromedome
Re: 40 mm BOFORS
« Reply #12 on: November 21, 2006, 08:39:19 am »
Try Paul at PSShips.
 chromedome
peterd
Re: 40 mm BOFORS
« Reply #13 on: November 23, 2007, 08:53:48 pm »
plan 40 mm Bofors 1:25
 :) ;) Peter
Re: 40 mm BOFORS
« Reply #14 on: November 23, 2007, 09:20:22 pm »
Much the same as these, but these are 1:40
longshanks
Re: 40 mm BOFORS
« Reply #15 on: November 23, 2007, 10:05:13 pm »
Hi Ken,
Yr asking about 1:32 bofors. Dont know if it helps , Italeri are releasing 1:35 bofors. It is the army version but I'm sure it could be modified. Got to be easier than scratch building.. I know it took me three months. If its the same quality as the one on there recent 80' Elco it will good quality.
tolnedra
Re: 40 mm BOFORS
« Reply #16 on: November 23, 2007, 10:53:43 pm »
Hi Colin
Single Bofors, or 40/60 (40mm bore by 60 = barrel length) Type 7, oil powered, Type 8 Electric, battery powered, Type 9 Electric, main ship's power. Type 6 Gyro gunsight with two "flip" shades. In the pod, an adjustable (slightly!) seat, a main switch on the bulkhead for the electrical ones, a control joystick moving up/down, left/right, shaped somewhat like an inverted "V" with palm levers which when pressed down gave the aimer control of the mounting. Headset with microphone for the aimer, Gun Direction Officer's loudspeaker positioned close enough for aimer and loader to hear. Captain of the mounting varied over time between the aimer and the loader, third member of the team loaded the letter-box rack on the rear of the mounting as required, from ready-use lockers around the mounting.At one time I used to teach the crews, unfortunately over the years any diagrams etc have been lost. Hope this helps, at least a bit.
Danny
colin-stevens
Re: 40 mm BOFORS
« Reply #17 on: November 24, 2007, 06:44:35 am »
Danny you tees, there i was getting all excited till the last line. one day i will get the detail i need to finish my large scale bofors.
thanks any way
colin
grumpy old XXX
Martin13
Re: 40 mm BOFORS
« Reply #18 on: November 24, 2007, 08:03:20 am »
G'Day Collin,
Your model of the 40mm Bofor is incredible - I can't believe the detailed workmanship - absolutely Brilliant.
Can you please tell me what type of material you have used and possibly in what order would the gun have been built.
I need to build two at 1:16 scale and have no idea
Don't suppose I can commission you to build them for me or anyone else for that matter...
thanks
Martin
colin-stevens
Re: 40 mm BOFORS
« Reply #19 on: November 25, 2007, 10:24:30 am »
martin, thank you. built it a long time ago, when i had more patience than i have now.
the barrell was turned up on a small lathe that did not have a adjustable cross slide to give the angle. instreads the head stock could be rotated. so the barrel was held betwee centres and rotated on dogs. a somewhat dangerous excercise, and how the job never hit me when it flew out.
as for making another, soory no chance.
i used the John LAmbert plans. it was made out of aluminimum for the barrel and the loaders area. brass rectangular section for the carriage and plastic for just about everyhting else.
if you are really stuck then why not find a commercial item and rescale it to suit.
have fun
colin
grumpy old XXX
Martin13
Re: 40 mm BOFORS
« Reply #20 on: November 25, 2007, 11:03:16 am »
i used the John Lambert plans. it was made out of aluminimum for the barrel and the loaders area. brass rectangular section for the carriage and plastic for just about everyhting else.
have fun
colin
Thanks for the info Colin, as I stated before-you have done a great job and I can see something like your model will require large amounts of patience.
Not a bad idea to buy a commercial built - at least I will have a 3D version to look at during construction
Thanks again and much appreciated
Martin
Re: 40 mm BOFORS
« Reply #21 on: November 25, 2007, 06:51:23 pm »
Ebay at the moment I can vouch for this chaps work it is excellent Highly reccomended item no    250190295320 this of course is on E bay UK
Re: 40 mm BOFORS
« Reply #22 on: November 25, 2007, 10:00:55 pm »
I am prety sure that is Les, who used to own Martins Models before it was sold on.
Re: 40 mm BOFORS
« Reply #23 on: November 25, 2007, 10:31:07 pm »
Ha Ha wrong Bob not Les he trades on E Bay as Martin the Modeler.I know Les Jones well but this Chap is Called Derek and does a very good job on these and guns fro the perkassa
Re: 40 mm BOFORS
« Reply #24 on: November 25, 2007, 10:36:24 pm »
OK, wrong again, not unusual!!
Page created in 0.167 seconds with 17 queries.
