Right Allan, lets get cracking.
Engines -
There's really only 2 types, CMB and the rest (I have a Novarossi 21 which is as quick as a CMB, but needs careful looking after).
CMB's are expensive and there are others (mainly Chinese) which are cheaper but still "pokey". The 45's can be used without gearbox so are easier to set up (and cheaper - the engine is more expensive but you save the cost of the gearbox).
Drive -
Submerged is cheaper but you get more lift at the back. This means the boat goes quick and corners well but is unstable (there are a FEW exceptions). Surface drive "looks" better and the boat can be set up to run dead flat but cornering suffers as they don't turn so tight. Surface is also SLIGHTLY easier to set up, but still needs extreme care when setting the shaft tube.
Exhaust -
No point in buying a good engine unless you use a tuned pipe. This can be "stuck out the back" like mine, or under deck if you've room. You will need a "quiet" pipe to keep under 80dB which is a strict rule.
Tank -
If you're going in for racing, there are 2 types, OMRA - where we race for up to 30 minutes per heat, which needs a big tank, or circuit (which is not as popular) and they only race for 8 laps so only need a small tank.
Radio -
Use at least 3 channels, one for rudder (using at least an 8kg servo), one for throttle (which must have a failsafe fitted) and one for mixture (as the tank lightens, the boat goes faster and runs leaner so needs adjusting - also easier to initially set up with).
There are a million and one other things but that will do for now.
It's decision time
Have a look at the OMRA website, go to Suppliers/Links. Dave Marles, Ian Folkson and Jon Wright are the main suppliers for our "toys".
Bet you thought you were going to get a bit of 'light relief' from the big boats - Ha
Danny
PS Where's the canal?
