Author Topic: Brushed dc motor spec  (Read 1882 times)
Staffs John
« on: May 18, 2011, 06:45:08 pm »
Hi All
I'm looking for a good motor for my MMM Brackengarth I would like to run on 24v I have found a motor i was wondering what you all thought.
The spec is
24v
   No Load
   speed 8400 rpm
   current 0.56 A
   Maximum Efficiency
   speed 6800 rpm
   current 3.5 A
   torque 80.0 Nm
   output 55.8 W
   Stall
   torque 440.0 Nm
   current 17.0 A
   Max Power
   95.0 W
   Typical Torque
   12.0 Nm
So what you think i have mixed reports on certain motors not giving the best performance.
Regards john.
john s 2
Re: Brushed dc motor spec
« Reply #1 on: May 18, 2011, 08:09:54 pm »
Sounds promising. Water cooling may be required. Is this the mmm Motor witch can take 24v? John.
« Reply #2 on: May 18, 2011, 08:28:12 pm »
8400 rpm on a large single Kort of 90 or 110 mm is rather excessive.
You need torque not rpm on props that size.
I doubt if you would need half that revs for decent performance and power.
« Reply #3 on: May 20, 2011, 06:41:53 pm »
Loaded by a large prop, I doubt that anything like the no-load rpm would be achieved.  To run at the "max efficiency " speed of 6800 rpm, gearing would probably be worthwhile rather than water cooling.
Page created in 0.083 seconds with 22 queries.
