Author Topic: Spektrum DX5 help  (Read 3135 times)
chris holley
Spektrum DX5 help
« on: May 24, 2011, 06:56:31 pm »
Just bought a spektrum DX5 but the throttleis a ratchet type. Would like to no if i can put a spring in it an how easy it is to do it?
thanks
brianB6
Re: Spektrum DX5 help
« Reply #1 on: May 25, 2011, 12:22:23 am »
Very easy Chris
Open the back of the TX
There is a flat spring against a ratchet on the back of one of the controls which can be unscrewed and moved to another one (silver piece at the top of the photo between the switches) and a spiral spring, usually on the other direction which is attached to a small plastic piece on a fixed pillar at one end and a protrusion on the other (not very clearly seen under the yellow and black wire in the right hand bottom corner) which gives self centering, and can be unscrewed and moved to the other direction.
If you want both to be the same type, I am sure your local dealer will supply a new spring, plastic piece and screw.
I have completely changed my Tx around and changed one of the controls to a slide pot and the other to a wheel.
andyn
« Reply #2 on: May 25, 2011, 08:29:55 am »
Phone up Horizon Hobby, and tell them what you need. It will most probably be free.
wideawake
« Reply #3 on: May 25, 2011, 06:48:31 pm »
Yes.  The contact we used to have there has moved on I think but I'm sure the service department will help.    They used to send the bits free (stripped from duff TXs)
Guy
john44
« Reply #4 on: May 25, 2011, 10:08:16 pm »
Hi Chris, fitting the spring instead of the ratchet is easy, but if you want to use some types of the forward only brushless motor ESC
on that transmitter the throttle stick has to be in the reverse/down position on start up.
I fitted a self centering spring on mine and had to change it back to run my forward only swamp buggy brushless motor ESC.
john
chris holley
« Reply #5 on: May 25, 2011, 10:12:59 pm »
oh right ok, well i spoke to horizion today an the woman said they dont send out parts if its damaged or broken send it in for repair but the dx5 is no loger able to take the spring.  {:-{
i will try again tomorrow i sent an email to spektrum an waiting for a reply
Page created in 0.025 seconds with 19 queries.
