Author Topic: Most enjoyable modelling jobs  (Read 3175 times)
« on: May 27, 2011, 08:23:58 pm »
As a counterpoint to Bryan's thread lets's look at what we like doing.
In my case, installing the running gear, electrics and electronics. Otherwise, building the hull in wood - a plague on GRP and styrene!
unbuiltnautilus
Re: Most enjoyable modelling jobs
« Reply #1 on: May 27, 2011, 08:25:13 pm »
Weathering the model, bliss, rust coloured bliss.
stubbsy
« Reply #2 on: May 27, 2011, 08:36:42 pm »
To link in with the other thread, conning someone else in to doing the jobs I hate.  O0
wartsilaone
« Reply #3 on: May 27, 2011, 08:44:12 pm »
It has to be the big bits, the bits that make a big difference to the model. Once done you stand back and think, Yeah that looks good.
nhp651
« Reply #4 on: May 27, 2011, 08:50:06 pm »
glueing on the last piece, lol {-) {-) {-) {-) {-)
« Reply #5 on: May 27, 2011, 08:54:08 pm »
Yup! Sticking on the funnel does it for me.
Bryan Young
« Reply #6 on: May 27, 2011, 09:55:47 pm »
Colin. Interesting. A sort of "yang and ying" thing. Half full or half empty.
But we all have highs and lows. I didn't intend to be totally negative in "the other place", but sometimes, just sometimes, you can plod along and not really see the end of the politicians mythical tunnel. Keep chugging. Unless you make a total cock-up the light will appear. Might take a decade or so! Bryan.
Notes from a simple seaman
« Reply #7 on: May 27, 2011, 10:02:44 pm »
Bryan, I think it's good to have a bit of both, as you say, we all have our highs and lows and being able to share them with others shows that we are not alone which can be comforting.
tobyker
« Reply #8 on: May 27, 2011, 10:06:00 pm »
The light at the end of the tunnel is the headlamp on the train that's about to run you over.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #9 on: May 27, 2011, 10:15:54 pm »
My favourite part- the very beginning, you have a blank canvas and the process of thinking it through lays ahead, all those little details that you want to add along the way, closely followed by sitting back and enjoying the finished article- though I get more moments of the former and not many of the latter....
« Reply #10 on: May 27, 2011, 10:57:44 pm »
building up the frames and keel of a plank on frame hull
brianB6
« Reply #11 on: May 28, 2011, 12:04:17 am »
All of it.
If I don't feel like one job today, then there is always a day when I will.  {-)
After all, I do it to have fun.  %%
Grub
« Reply #12 on: May 28, 2011, 12:14:15 am »
Sailing it!
Peter Fitness
« Reply #13 on: May 28, 2011, 12:22:09 am »
All of it.
Pretty much my philosophy, too.
Right from the point when I start a model, I have a mental picture of what it will (should) look like when finished, and this keeps me going when I strike a difficult area. In particularly troublesome bits it's sometimes best to leave it for a while - days even - then come back with a clear head (as long as you haven't been partaking of some medicinal alcohol :o {-) ) and start again. Having done this, it's remarkable how often a seemingly impossible job becomes easy.
However, if pressed as to my most enjoyable job, I would say fitting the details which really bring a model to life.
Peter.
gwa84
« Reply #14 on: May 28, 2011, 01:08:59 am »
cant beet firing an ic engine up for the first time the anticipation is great will it run wont it will it perform well or just slowly give up on you
« Reply #15 on: May 28, 2011, 02:24:13 am »
Making the black & the gold & the wooden lagging components is very satisfying ..... it is all 5/32 OD tubing on the engine & 5/32 + "1/8 inch OD on the deoiler & M2 hex head brass head on the 4 & 5 bolt o-ring sealed flanges........:o O0 Derek
brianB6
« Reply #16 on: May 28, 2011, 05:01:01 am »
I agree Peter, making something for the third time because the first two were not right is a bit frustrating, (as in your other post) as is trying to get small items off ones fingers after the super glue has dried.   :embarrassed:
Paxton
« Reply #17 on: May 28, 2011, 05:43:22 am »
and then planking up the finished frame.  Very therapeutic and you can see steady progress, unlike when making fittings etc.
Dekan
« Reply #18 on: May 28, 2011, 03:43:34 pm »
Turning on the TX and RX for the first time, does it for me.. :-))
mikearace
« Reply #19 on: May 28, 2011, 07:40:47 pm »
Having the box delivered when the wifes at work and hiding itin the garage rafters and that moment when she goes to the washing maching in the garage and comes back aand doesnt say a thing and you know you have got away with it.  Satisfaction!! Sorted!!
Popeye
  • I see no ships!
« Reply #20 on: May 28, 2011, 09:24:30 pm »
The maiden voyage - when everything works as it should :-), trim is exactly as intended :}  and there are no leaks :-)).
Confucius he say, 'if all else fails.......reach for the  Red Top-Stop'.
« Reply #21 on: May 28, 2011, 10:02:12 pm »
Hi
so far - I'm new - it's been reading the forums here. They are damned addictive and beat everything on TV. Also I've noticed the old magic mead consumption is going up whilst reading these posts.
Regards Norseman
