Author Topic: y2k  (Read 3389 times)
slug
y2k
« on: May 31, 2011, 07:13:17 pm »
i am building a y2k and the plan states a 3/4 inch diameter mast looks a little thick? is this ok also where can i get small screw eyes for the rudder pins which are 2mm brass wire does one control the mainsail and jib as in a micro magic hoping you gents can help   slug
tony23
Re: y2k
« Reply #1 on: May 31, 2011, 08:47:24 pm »
No, that cannot be right what's the size of the boat?
slug
Re: y2k
« Reply #2 on: May 31, 2011, 09:12:42 pm »
sorry read plan wrong 5/8 is the sizex34" high i have some 1/2"which i think will do boat is 36x10"  gaff rig thank you for your help   slug
rmaddock
Re: y2k
« Reply #3 on: June 01, 2011, 11:53:22 am »
 :-)) Sounds like my sort of mistake. My wife laughs at me. I spend hours carefully working out what I need for a job and then invariably come home from the shops with either twice what I needed or a half.  >>:-(
Re: y2k
« Reply #4 on: June 07, 2011, 01:10:11 pm »
Screw eyes from the local hardware store or online. They often be brassed, as opposed to brass, which may prove stronger.
I also use cotter pins for small connections, just drill a hole and glue them in after trimming.
