1st would 1 of the nice mods please move this to the appropriate section as i wasn't sure where to post this.
Well I decided to build something for my GF to use when she takes me to the lake. As she loves flying around in her cesna or whatever it is i thought a surface running plane would be good (was thinking of a catalina) however she decided that she'd like a radio controlled rubber bath duck. Thought I'd do it as a list incase anyone wants to do similar (though I doubt it)
quick list of things needed/tools:
1 giant duck £16
1 rudder £3
2 motor pods from baby severn
mtroniks viper esc
giant cod 4 channel 2.4 ghz radio gear
hot glue gun
pack of cheap craft knives from hobbycraft
small file
So 1st was a trip to buy hawkins bazaar to buy a giant bath duck:
then to cut the back off:
as propulsion I'm using some motor pods from a baby severn (thanks ayrshire andy, who also supplied the esc) i got a rudder online, meaning i only needed to cut 3 holes in the bottom
I fitted the motors, surrounding the holes on both side with glue using the hot glue gun. When i put the shaft for the rudder in the thread didn't go down far enough so i needed to make a spacer. Being on a tight budget of around £0 i used an old bottle lid with a hole cut in it, put it over the rudder shaft and glued down using the hot glue gun again. Still wasn't quit enough so I cut a couple of 'washers' out of more bottle tops.
stuck in the bath for a quick test of the motors, and apart from running into the sides alot, it works ok, now i just need to fit the servo and decide how to fix the cover back on!
There not much to look at, not very difficult, but my 1st attempt at rc'ing something rather than buying other peoples models.
i expect criticism, so fire away.
