I've just spent a very manly afternoon casting ballast.....well, half of it anyway.
First, I mixed up my DIY green sand:
Not very green, is it? With the builder's sand fresh from the bag it seemed to have about the correct consistency so I didn't add water. Oh, I did 10kg of sand to 1kg of bentonite clay. It's a bit more than the 8% I've seen talk about but not by much.
Next, the plaster plug went into the bottom of a make-shift wooden box:
Note that the bottom of the box is not attached as you need to remove it later.
Then, using a stick to tamp things down, I filled the box with green sand making sure to work it well round the plug until it was full to the brim.
Then another board is put on top and the whole thing slipped over whilst holding the breath.
I removed the plug by the simple expedient of sticking something pointy into the plaster and lifting it out.
I was not unimpressed by this first effort
and so ploughed onwards.
I used my trusty old Coleman Peak One camping stove to melt the lead in a normal domestic pan. I went for steel as I was a bit worried aluminium might not be up to it.
I've no pictures of it being poured as I was busy
However, it was not too hard. The pan was, of course, heavier than you expect. I simply poured gently directly into the mold and a few minutes later........
It doesn't take long to solidify so I didn't have to wait long either to see if it had worked:
YEAH!And, finally, here are the ballast and plug together. I think it might fit.
