I'm loosing the will to do this entirely properly and I'm getting increasingly desperate to see this boat on the water so I'm cobbling the sheeting system together as quickly as I can.
The main sheet is now in place. The travel is probably rather limited and I may never be able to run really well but, then again, I've read that these old gaff boats weren't often run anyway. The rig would tend to induce an uncomfortable wallowing roll on a run so they normally stuck with a broad reach. That sounds like a good excuse to me! I shall stick to it!
So, under the foredeck we have the winch (the left hand one as seen here). A pair of copper pipes route the sheet loop down to the level of the lead ballast. I intentionally left this area completely clear so that the sheets can run under the floors. You can also see the main sheet coming off the winch loop down there.
Astern, there's a single block to hold the winch loop. It's held on the string tied around the copper tube and is out of site below the motor in this shot.
The main sheet itself goes through that self same pipe. You can just see the flared end at the bottom of the alien-esque slump of epoxy. It's routed up to deck level and emerges just behind the wooden bollard. Again, I'm hoping to hide it under a coil of rope - or some such. From there it'll go to a block on the runner on the counter top and thence to the boom.
I'm sure the friction is awful and it'll last less than 10 minutes but I don't care.
I'll just motor around the lake like many real size yacht owners do anyway.
