halcyon hi there,
I am not sure if you have the answers you require from the Forum but, as I have previously stated, there are many ways of doing things. I will explain my way and bear in mind, this is my way - some people may think its wrong or right - all I'll say is ITS RIGHT FOR ME
First of all; there are several golden rules when working with fibre glass:
1. The mixture ratio between your polyester resin and your hardener. This is pretty critical.
2. The ambient temperature of the area you are working in. This should be anywhere between 18 degrees and 20-22 degrees. Obviously the warmer it is, the quicker the resin will go off and the shorter the working time.
3. Your resin to Mat ratio - e.g. for every 1lb of Mat in weight you must have (for the average laminator) 2 - 2.5 lbs of resin.
4. Cleanliness of the working area and surrounding areas.
My Method:
I prefer to skin the outside of the hull and I tend to plank the hulls I make in either obichi or mahogany wood. These are slightly harder timbers than balsa (which are working with).
Rub down the hull. Make sure the hull is true and fair. Any discrepancies/hollows/bumps either sanded smooth or filled with car bodge filler and sanded in. When this is done, I give the hull one coat of just pure resin with hardener added. I will not put percentages of hardeners I use to the resins as different resins vary in the amounts you mix.
Once the resin has hardened, roughly about 30-40 minutes, I give a very light sand down with course paper knocking off any runs in the resin - I then use tissue Mat. First of all, I work in small sections - obviously depending on the size of hull. I will normally start at the bow to the half way mark and paint resin on their - just resin and hardener mix on first then lay the mating on the top of the wet resin and stapple the resin through the mating. This removes any air bubbles or creases. I have used a fluted roller on a larger hull, which does aid the procedure. Then, whilst that is starting to set - I move over to the opposite side of the hull and the opposite corner at the stern working up from the half way mark to the centre again. Same procedure resin on first, mating on top and stapple the resin through removing all air bubbles.
I then go opposite on the hull - from the stern to the middle meeting where I put the first piece of resin. Once that is done, I do the last piece.
I leave this to go off for another 40 mins - this is where the smell comes in - as the resin starts to cure. What you can do, which I have heard of, but never actually done. I place the hull in a large polythene bag whilst curing - Ive never personally done this (scared in case the bag blows up
When its cured (resin gone off) I search for air bubbles and defects where the resin hasnt wetted through properly and mark so when I put the top coat of resin on , I know just to stapple in harder at that point.
Before I put the final coat on - I put black felt tip mark pens on the tissue Mat - then I cover over the top these are guide lines for when I rub down with coarse wet and dry working through to fine wet and dry - smoothing the hull off and finishing. If I rub any of these black felt tip pen marks off I know Ive gone too far. If I did rub too far down - I would put another coat of resin on top and allow it to cure.
So, in theory, there is two coats of pure resin and one with tissue Mat.
BEFORE I DO ANY RUBBING DOWN - I ALLOW THE HULL TO CURE FOR AT LEAST 48 HOURS.
All I do now, is to coat the inside of the hull with just pure resin with hardener mixed. Work that into every nook and cranny.
Well, hope this helps and gives you some insight.
As I say, its just one method - plenty more out there - there is also an epoxy method. These all have the good and bad points.
its up to you to make your decision.
aye
John E
BLUEBIRD
