Here we go guys,me and mike got together again today and ran our boats.
We took it in turns running and gps was used each run.
1st up is mikes scratch built cat running:
Leopard 4060,1500,swordfish 120amp ESC,and 6s2p 5000mah,40c batts and 42mm prop.
Temps were cool needs to prop up
http://www.youtube.com/watch?v=uSWuMG4Ien0
2nd up is the saga gt
Leopard 4074,2000kv,120amp esc,4s2p 5000mah,30c batts and 45mm cf prop
temps of motor and batts were barley warm,but the ESC was quite warm to the touch.
http://www.youtube.com/watch?v=uPVAzEwKOAE
3rd run was saga gt only this time with 47mm prop.
again motor and batts were barely warm but ESC was on the limits.
http://www.youtube.com/watch?v=_kB21NXsCQk
4th run was mikes pursuit.
Running leopard 3674,1900kv on 4s2p 5000mah 40c,t180 esc and 37,3 blade
there is a vid but on mikes phone.
Conclusion for the day,abit dissapointed,i moved the CG forward and was slower than yesterday but more stable and i need bigger esc and some 3 blade props,also gonna get 2 x 3s,5000mah,30c lipos and run 5s2p with smaller prop,also considering off setting the rudder instead of inline.or next option is run higher kv due to ltd room for propping up.
But happy with the results so far and i know ther is still more to ring out of it LOL
will post vid of pursuit run shortly
