Decided to start to build the hangar but had to give it a lot of thought as it isnt a bog standard 'traditional' square box type housing. There are a lot of angles, nooks and crannys curved edges and so forth. Used the plan to make templates as shown below:
Normally for a square box I would build it round the coamings to get a nice snug fit but the shape precludes this. I have measured the width against the hull and the hangar coamings will be an exact fit against the deck edges of the rounded side of hull moulding if that makes sense so it will be easy to make the deck opening it that makes sense. Well it makes sense to me now but I might have an oh my god what did I do moment later in the build!!!
As the plan shows starboard view, plan view, hangar end looking forward but not port of hangar lokoking aft there are some prrts that cant be done by template but will need to be 'sized' as the build progresses.
Having cut the templates I have made a start, commencing with the roof and also internally a former the sahme shape as the roof. Having cut this then attached the first side and so forth.
After a few pieces cut and glued the basic shape is starting to come together.
A bit rough and untidy and obviously a lot of sanding and cleaning up to be done but fairly pleased so far. I will leave it 24 hours now to fully set before starting the port side and then forward end of the actual hangar and then the platform that supports the emergency steering position and whip arials.
