Hi there
As promised I am finally going to start a build log for the ST Cervia. This is my first scratch built scale model
So I'm sure there will be many trials and tribulations along the way
progress has and will continue to be slow as I am trying to ensure that I get things right the first time.
Firstly a special thanks to brianB6 for giving access to the plans for this vessel, its much appreciated
Secondly thanks to Bluebird for his wonderful build log and constant assistance provided up until this point,
would have given up before i ever started without the support.
OK and on with the build:
At this point in time I have almost finished sketching all the frames and the keel onto plywood, however i am still
waiting on a propshaft before i cut the keel and the last few frames, hopefully i get the shaft next week.
I have a tamiya 540j motor that i will be gearing down using the mfa Olympus 2.3:1 belt drive. I need a universal
coupling for this, so have to find out the thread size on the belt drive, i suspect its m5 but I'm sure a trip to the
hardware store with drive in hand will give me a definitive answer on that one.
The frames and keel are being drawn up on 6mm marine ply, and I will be planking her in limewood.
Anyway, I was trying to keep this short so I might just throw up some photos of where I am at:
1
The french curve set is a real life saver for copying curves...
2
3
4
5
6
Photo 6 shows the motor mount I have designed for the belt drive system
My major problem at the moment is working out how to get the correct deck camber, I was thinking along the lines of:
7
But do not know whether to stick with a 2mm height at the centre for the length of the vessel and vary the radius of the
camber or keep the radius the same but vary the height? any suggestions on this point?
I know its not much, but any hints and tips, as well as constructive criticism will be greatly appreciated.
Cheers,
Tim
