John Mk2
Very probably not - the "power" windings are just the same as a sensorless motor
(the sensor windings are, I believe additional coils which only provide the timing signal to a sensored ESC)
OK , I have read the spiel on the Nosram Dragon and the sensor is a hall effect device, and indeed they are hot car motors with the hottest (9.5T) at 4700 kV
Much more likely is that the motor comes from a hot car, and to get the full performance it is necessary to change the ESC advance and possibly also other things.
Most ESCs come with a default setting which will hopefully get most motors of the intended power going reasonably well with the intended load (often air propellor) AND they are broadly expected to drive an outrunner BL motor
This is both an inrunner, and a very fast one, so I would expect to advance the ESC
Thyis is normally possible even without a programming card if you have the instructions and preferably four or more fingers (becuse you have to count bleeps)
Let us know WHICH Dragon it is and what ESC you are using, and we may be able to help more
andrew
