Author Topic: Invisible drive for the Radar on an AZIZ?  (Read 4244 times)
« on: March 05, 2007, 05:44:00 pm »
...via an email to Mayhem.
Anyone got a good idea how to make invisible drive for the Radar on an AZIZ?
( I don't want a rod going down through the deck. )
catengineman
Re: Invisible drive for the Radar on an AZIZ?
« Reply #1 on: March 05, 2007, 06:15:41 pm »
Hi, I did think of trying this on capt jacks aziz  but settled for the rod through the deckhead.
With the use oF an old bicycle brake cable I did think of running it up the side of one funnel and then with gentle bends through the bottom of the radar post, It would have to go through the  radar platform at a slight angle to be able to run down the funnel casing. as I said I did not get to try this as time would not allow but I did think I had a good chance of getting it to work.
Richard,
riggers24
  • Just full of stupid questions
« Reply #2 on: March 05, 2007, 06:38:33 pm »
Somewhere on the forum there is a web address for a site that has very small motors and for the life of me I can't find it
I will finish the crash tender someday - Still got tooo many toys to play with
flybobby
« Reply #3 on: March 05, 2007, 06:57:40 pm »
Where can I find more pictures?  Love the quality and detail ;)
ron parker
« Reply #5 on: March 05, 2007, 08:21:32 pm »
have a look at hunter systems, they have a tiny motor 13mm x 4mm to run on 3 to 6 volts which might fill the bill, it might run slowly on 1.5 volts
               ron parker
HS93 (RIP)
  • I cannot spell , tough
portside II
  • tugs at rest
« Reply #8 on: March 06, 2007, 12:27:18 am »
you could try the radar unit from JJC ,a bit fiddily on the soldering but a very small motor
JayDee
    • JOHN DOWD
« Reply #9 on: March 06, 2007, 12:51:40 am »
Hello,
Inside a Mobile Phone that "vibrates", when a call is received is the smallest motor I have ever seen!.
Seen them on sale at Computer Fairs, no idea which Phone they were made for, but they are VERY small !!.
Just an Idea !!!!!!!!.
John.  :D
http://www.john-dowd.
Subculture
    • Dive-in to Model submarines
« Reply #10 on: March 06, 2007, 06:45:21 am »
These guys sell a tiny pager motor with a planetary gearbox-
http://www.solarbotics.com/products/index.php?scdfa-250100084-viewDetail-productzq3945zq4categoryzq37=true&frm=sbfi
RPM is 1200. You can slow it down further using a rubber friction wheel reduction, if required.
Didel are also good for small motors and other paraphernalia
http://didel.com/Frames.html?MainFrame=News.html
White Ensign
  • Limits must be limited!
« Reply #11 on: March 06, 2007, 10:47:20 am »
The smallest  motors available I have seen are out of 6mm dia, some available with gearbox and reduction down to 1:1200... It`s worth a look anyway.
The page can be found under:
www-lemo-solar.de
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
Eddy Matthews
« Reply #12 on: March 07, 2007, 12:01:53 am »
Page created in 1.605 seconds with 21 queries.
