Deans Marine : MARINE. 1 6 volts / 1amp
wt 15gms 29mm x 34mm x 5mm
This unit has been designed to Deans Marine Specifications for use in the COMPACT kits and the smaller lighter models in the range.
This miniature unit weight only 15gms and gives full proportional speed control in forward and reverse The unit is designed to run on the BEC system in
that the power for the R/X AND THE DRIVE MOTOR is taken from the R/X power supply . This unit is waterproof and features one touch set-up, and is
prewired with a plug. £17.75
Richard
