Continuing on in my slip-shod way....
Constellation's boats got final paint, inside and out, though there's some touch-up to do, and I modeled cradles for the in-board boats (Launch, 1st & 2nd Cutters). These are right off my head and aren't based on any historic data as I haven't found anything certain for US warships circa 1856.I've never been happy with the red oak crown bitts I made years ago, so modeled new ones, a little more bulky and with better sized sheaves. Speaking of sheaves, I rework my 3D models of blocks to take 8mm sheaves and printed some shells (to get brass sheaves) and some with sheaved modeled in for most things that won't be moving much, like bunt-lines, halyards, etc.
The pin-rails have been drilled for mounting pins, primed and painted, but the bulwarks have to be prepped before they can be installed. The bulwarks have to be drilled for the mounting pins, and painted, because painting behind the pins once installed would be a pain. The hammocks are 3D printed on trays and epoxied on top of the wooden bulwarks. They trays were made a little wide to accommodate my sloppiness in making the bulwarks, and have to be ground flush with the inside and outside surfaces. The a wooden strip in glued on to cover that seam. Another thing to be done before the pin-rails are installed. I'm working on the starboard side currently, which includes painting the hammocks to look, I hope, like canvas.
A while back I discovered Constellation was rigged with rigging-screws (turnbuckles) as opposed to dead-eyes-and-lanyards, on her lower and top-mast shrouds, from when she was built until sometime in the 1890's. I 3D modeled these, hoping to find someplace to lost-resin cast them in brass or bronze for me, but making the 60 or so I need would run over $1,000 US, so I printed them and popped a pair on the model, under tension, to see how they'd hold up. They had been there since November of 2023 without breaking, stretching, or deforming, despite my bumping into them near every time I reached for something on the hull. They're non-functional, basically just for show, but so are the lower shrouds. In any case, there's always a chance of breaking one or more in my handling the model, so I need to be able to replace them as needed. To that end, the chain-plate are held to the hull with a brass round-head wood-screw, and the rigging-screw to the chain-plate with a brass nut & bolt.
