Author Topic: Model Boat engine  (Read 7327 times)
MikeA
Re: Model Boat engine
« Reply #25 on: July 24, 2011, 11:13:19 pm »
yes its a good thing. if makes life a hole lot simpler because if it does then if has a servo:
 these servos are standard in all rc systems. brands, sizes and power vary but they all look the same pretty much. they are basically an electric motor with a gear box and a crank which turns about 90 degrees. To this you can attach a throttle for a petol engine or a rudder.
 this servo has a rudder connected to it. the rudder is under the hull which is connected to a axle and then its connected to the white disk. a pushrod moves the disk which is connected to the servo.
Now with a servo its very simple to install and set up. if ya cars dont have one of these types of servo in, then itll be a right s**t to use a car one unless you can actually make a servo yourself.
WelshBuilder
« Reply #26 on: July 24, 2011, 11:19:22 pm »
Ill check when i open one up, hopefully it will for the steering of the car but if not im sure you can buy steering servos.
MikeA
« Reply #27 on: July 24, 2011, 11:47:07 pm »
servos are generally quite cheap 3-5 pound (as far as rc is concerned) but a servo wont work without the radio gear which is when the bill starts piling up. A basic radio kit on ebay can cost between 20 and 30 pound on ebay (not including postage). Now i have tried the budget route of buying in ebay auction a 99p futaba transmitter 2 channel with sticks. I managed by luck to match it with a hobao receiver.  here is a picture of a servo connected to the receiver then it all powered by a battery pack:
doing it the way i have done has been long and a pain in the stern. in the end ive had so many problems doing it budget that ive spent 30 quid trying to rectify the problems. I should have just bought new in the first place.
im trying one of these next. ive heard good reports about these radio kits. there cheap for what they are and do the job:
its called an fs gt2 they can be as little as 18 pound on ebay brand new.
i seriously doubt the cars you have judging by there size and price in argos that theyl have anything you can use. the motor will be lacking power, youl have a major engineering task to modify there steering mechanisms to work for your boat. it can be done but you have to build a gearbox for them with a self centring spring on it.
theres more to come
MikeA
« Reply #28 on: July 25, 2011, 12:12:07 am »
even if you bought a servo it will not work with the car radio system unless it is digital proportional. you move the sticks on your transmitter remote, the receiver picks up the instructions and sends electricty to the servo to make it move. The servo has on it a sensor which tells the receiver its got to the position it was told to go to. Toy cars dont have this feedback technology in them and so the servo will just stay where it is and wont come back when you let go of the stick again.
gwa84
« Reply #29 on: July 25, 2011, 12:54:04 am »
i use the gt2 verry good systems for the price and you can get sper ecevers for less then a tenner  :-))
WelshBuilder
« Reply #30 on: July 25, 2011, 09:19:07 am »
If it cant be done or not worth doing i wont do it simply as that, but ill seriously rethink building rc model boats i dont have the money to throw around on things that i could make a mistake with and waste it. I may go back to building statics.
MikeA
« Reply #31 on: July 25, 2011, 01:34:46 pm »
if you can build statics then youl be able to build rc. im on a tight budgest myself and have 4 kids too so i know what its like to be allways poor. But when me and my kids go boating it makes a nice day out and worth the effort. You have to be patient though and gradually build up the parts that you need. You have to make sacrifices on other luxuries Ive stopped doing things like drinking and buying cds etc because id rather do this at the minute.
gwa84
« Reply #32 on: July 25, 2011, 07:59:18 pm »
if you send me a pm ime sure i have some bits and bobs lying about and could set you up with the things you will need for a springer
i should have
prop shaft and prop
motor and motor cupling
servo and meckanical speed controler  i will set this up on a bourd for you so it wil work well
and i will have a root around see if i have a sper recever and controler ime sure i have one but i think the batery covers missing but i used a peace of card and tape to hold the bats in
i will be back home next week as ime away working but should sort the bits out for the price of postege  ok2 :-))
Page created in 0.015 seconds with 19 queries.
