Hi all thought id post some more pictures of the build, took Peters advice and used a 1. 1/4" x 1/4" home made motor mount
i have left out for now the water cooling holes in the mount as i think it will weaken it to much, 1/8" drilled top to bottom,
could i drill front to back or would this have little effect i dont know,the mount is bolted in so i can take it out if need be,
drilled the p brakets in and the rudders all lines up perfectly, have kept the shaft angle as low as posible so i can go up to
a 2" prop, dont think i will need to im thinking 1. 3/4" might be ok. Cut and put the ply skins on and planked the deck
i wasnt going to plank it but changed my mind its only balsa planking so i can stain it havnt tried this before so see how it
turns out if you dont trie you dont know thats me, i shal get on now to finish all the hull fit the keel band and all the
stiffners then prime the hull. back soon.
chombo
