Author Topic: Making frames for a plank boat  (Read 6461 times)
roy boutilier
« on: July 31, 2011, 07:25:26 pm »
I saw a post by a fellow who made his boat frames by first making the frame with seperate boards then put the out line from his paper frame shape onto this wood frame. His wood frame, for lack of better words, looked like a picture frame. Not solid in the center like a full plywood frame.  It was a very in depth post with lots of pics and went through all of the building from lay out to planking to make a finished hull. Can any body help me find this post?  If not, can some one else show me this way to build a steam launch?  Thanks for your time on this,   Firsttime
MikeA
roy boutilier
Re: Making frames for a plank boat
« Reply #2 on: July 31, 2011, 09:52:23 pm »
Sorry Mad Mike, it is not the build I was looking at. At my age it is hard to remember where things are sometimes. Thanls for your help, firsttime
MikeA
« Reply #3 on: July 31, 2011, 09:58:50 pm »
you going to build a steam boat then? ill look a bit further
Was it a steam boat build, have you looked threw the masterclass section?
« Reply #4 on: July 31, 2011, 10:22:46 pm »
Hi  firsttime
Is this the one you are looking for
http://www.modelboatmayhem.co.uk/forum/index.php?topic=19422.0
aye
john
roy boutilier
« Reply #5 on: July 31, 2011, 10:44:34 pm »
Mad Mike, yes and yes. I can not believe I did not save it when I read it.
Blue Bird , no. Intresting build but not the one . Thanks for your try, firsttime
roy boutilier
« Reply #6 on: August 01, 2011, 09:17:07 am »
OK folks, I give up! I can not find the post. I do not need to bother any body with this search any more. Thanks to Mad Mike and Bluebird for their participation in the hunt!   Bluebird, your way of building frames looks to be what I can use with the exception of using buildup wood frames instead of plywood. Your post is very complete. I am a new person to this forum and have been looking at it for some time. I have been modeling for years  but this is my first time into steam. It is also my first time for building a scratch plank on frame boat. Hope to get it right the first time. The boat I am going to build is the steam launch La Mouette. Found the plans on john-tom web sight.   Thanks again,    firsttime
MikeA
« Reply #7 on: August 01, 2011, 09:29:03 am »
sounds cool, put some picks up of ya progress wont ya  :-))
roy boutilier
« Reply #8 on: August 01, 2011, 09:42:11 am »
Hi Mike, ya, that is another thing to learn!!! I am not a PC whizz, but it seems to be a way of life on this forum. I will try when I get something to show. I can tell you that the boat will be 42" to 48" long. I will be using an old Cheddar Puffin steam engine for power. Not really sure how much boat it will push.  firsttime
MikeA
« Reply #9 on: August 01, 2011, 09:59:24 am »
do you mind me askin how old you are? if ya got a digital camera ask for help on here. its easy enough. Dont know nothing about a cheddar engine though.
roy boutilier
« Reply #10 on: August 01, 2011, 02:04:14 pm »
Hi Mike, 68 and happy! Finding out what the Cheddar can do is the next thing I need to do so that I will know how long the boat can be for its power range. I need to know so much before I can even start to build the boat. Not sure where to post for the engine info. This is really a good forum for steam.     firsttime
MikeA
« Reply #11 on: August 01, 2011, 02:23:08 pm »
i think if u put your posts in the general section you might get more notice. Im 25 i think im one of the youngest here lol. Ill look around for info on cheese engines.
MikeA
« Reply #12 on: August 01, 2011, 02:26:55 pm »
does it look like this?
theres an 8 page brouchure here with them in
http://www.stuartmodels.com/pdfs/Puffin-Brochure.pdf
here is a site of steam boats including this dvd pack of a build
http://www.mainsteam.co.uk/steamboats.htm
MikeA
« Reply #13 on: August 01, 2011, 03:04:20 pm »
theres also this from kingston mouldings thats uses the cheddar puffin engine at the top it gives you the size of the boat this should give you an idea of what size to do:
http://www.kingstonmouldings.com/pdthameslaunch.htm
roy boutilier
« Reply #14 on: August 01, 2011, 04:09:14 pm »
Hi Mike, do not let age be a concern in this hobby or any hobby. Everybody can be a help. The young have new ways and the old have experience. I feel that can be a good blend. In the end we make our own decisions based on what we learn and what we know. The pic you showed is the new style. I have the old cast style. Do not know if there is any difference in power between the two or not. The launch you showed is 45"X9". If I build my launch to 48"X13 3/4" it makes the hull harder to move If I use 42"x11 3/4" it should move easer but I will lose space in the hull. Do not know at this time if that is a real concern. These are the things I hope to find out from the people on this forum.    firsttime
MikeA
« Reply #15 on: August 01, 2011, 04:22:39 pm »
well i sugest you post in the general section. i think the post will get more notice there.  forgive me for my ignorance if 48s too long and 42's too short why not go 45? or is it all about scale?
roy boutilier
« Reply #16 on: August 01, 2011, 04:32:12 pm »
Yes Mike, I could make it 45" long but the beam would be about 12 1/2". wider than the other hull you showed. This is do to one being a river type hull and the one I want to build is more of a work type hull. FYI, the wide a wake build has a very similar hull to the La Mouette. Take a look at it. It is a very nice build,    firsttime
MikeA
« Reply #17 on: August 01, 2011, 05:22:14 pm »
seen the wide awake build. its very nice boat. theres lots of nice boats here.  I would definately sugest you start a new thread here:
http://www.modelboatmayhem.co.uk/forum/index.php?board=84.0
more people will see it and give you a better guide on how to start and more people will be able to point you to the right threads you need
roy boutilier
« Reply #18 on: August 01, 2011, 06:20:36 pm »
Thanks  for the info Mike. Will see what I can do.  firsttime
Page created in 0.189 seconds with 17 queries.
