Pages: 1 [2] 3 4   Go Down
Author Topic: Dumas Crist Craft Run About Speed boat  (Read 23105 times)
Meyer
Re: Dumas Crist Craft Run About Speed boat
« Reply #25 on: August 16, 2011, 01:17:03 pm »
Hi Martin,
Thanks for your input, its a great site for help and advice, "its an interesting item, " this auto bailer" !!!, I try and get an angle up on it,
cheers for now Roy
andyn
« Reply #26 on: August 16, 2011, 01:18:12 pm »
I've seen more success using bent pipe in this arrangement...
The top of the tube has to be way above the waterline... As the boat goes along the rear facing end of the tube outside the boat creates suction, and pulls out any water in the boat.
6705russell
« Reply #27 on: August 16, 2011, 01:39:42 pm »
Not a very nice looking arrangement on a scale boat i must admit  {:-{
Russ
Meyer
« Reply #28 on: August 16, 2011, 01:41:26 pm »
Hi , Andy,
Thanks for the drawing, very interesting, "I can see that this bent pipe , would be very effective", in a speed boat, I will try this on my next build, thanks again for your posts and interest.
andyn
« Reply #29 on: August 16, 2011, 02:45:31 pm »
Russ
Well you can use thinner pipe and tighter bends... It's only a laptop pad drawing on paint ;)
MikeA
« Reply #30 on: August 16, 2011, 03:17:02 pm »
http://www.modelboatmayhem.co.uk/Common/Glow%20engines/Tweak%20maint.htm
 i just bought the stuff today to fit a sypon autobailer. bit of ally tube and some silicone pipe.
another one here. good pictures:
http://www.modelgasboats.com/Bernoulli_Water_Bailer/
Meyer
« Reply #31 on: August 21, 2011, 12:33:51 pm »
Hi, while i'm waiting fo prop andd stuff ,  here's a few old build piics,
Meyer
« Reply #32 on: August 21, 2011, 12:39:52 pm »
Hi Mike, thanks for the scan , and your valued time, I'll see this monster in the pond yet, !!! thanks again,
MikeA
« Reply #33 on: August 21, 2011, 12:51:23 pm »
have you got it sussed yet ? ;)
Meyer
« Reply #34 on: August 21, 2011, 01:47:16 pm »
Hi,Mike, thanks I think I got it sorted now, !!! well I'm working on  my mates steam engine , while I wait for prop and  heat shrink wraps,, then I'll post some pics, thanks again,
pompebled
« Reply #35 on: August 21, 2011, 10:23:10 pm »
Russ
When you install the backwards slanted tube in the bottom, out of the propwask, nobody will see it and it'll work even better.
(distinctively better than a forever leaking autobailer...)
Please seal the internals agains water.
Regards, Jan.
Boaters are nice people
Meyer
« Reply #36 on: September 18, 2011, 02:52:14 pm »
Hi Jan,
Thanks for your post, been a away on hols,
while I'm waiting on new motor and speed controller, I'm not to sure on how to ? or wear to fit this water scoop, any ideas, as I have no space between the rudder and prop,
there a pic,
MikeA
« Reply #37 on: September 18, 2011, 04:37:20 pm »
where it is now is fine  :-)) try to keep up hill flow to a minimum and the tubing short as possible but still allowing for nice curves no sharp kinks.
Meyer
« Reply #38 on: September 18, 2011, 07:07:04 pm »
Hi Mike,
thanks for your post, Cheers for info, I've made my own prop shaft, and fitted the original bronze 3 blade propeller , now I'm building up the acrylic gloss, and sanding down on 220 grit, about 10 coats to go, !!!, finish is starting to look great, can'nt wat to get this baby on the water, !!!
MikeA
« Reply #39 on: September 18, 2011, 08:37:41 pm »
10 coats!!! are you deliberately trying to drag the build out!!! you know the other day you said you got your money back. did you have to return the item or did they just give it you?
Meyer
« Reply #40 on: September 18, 2011, 10:22:38 pm »
Hi, no drag out,!!! I'm having fun, yer I return them,
MikeA
« Reply #41 on: September 18, 2011, 10:43:32 pm »
what motor you got in mind now then?
Meyer
« Reply #42 on: September 19, 2011, 11:00:31 am »
Hi Going :
Mtroniks G2Hydra50 combo , will water cool motor, !!! " At least thiis will work, !!! this will give a good model speed,
Code: G2Hydra50c
50A Waterproof brushless speed control and motor set for model boat
The Genesis Hydra50 combo is a Forwards and Reverse Brushless Speed Control comlete with high power 600 can size inrunner motor designed specifically for use in scale RC boats.
The Genesis Hydra50 has a 50Amp Brushless motor limit, this is a rough equivalent to a standard, stock 600 or 700 can size brushed motor.
The Genesis Hydra50 Brushless speed control has been designed to fit straight into any RC model boat as a direct replacement for your Brushed speed control and motor. The set up is a no nonsense, one-step procedure making it very easy to get up and running within minutes! The Genesis Brushless Speed Controls designed for use in RC boats are all 100% waterproof giving you that extra peace of mind should the worst happen and you have to retreive your model from the graveyard under the pond!!
The Genesis Hydra50 benefits from 5 years worth of research and design work carried out by the Mtroniks design team with help from a few well known RC scale sailors. What this has resulted in is a Sensorless Brushless Speed Control that works and feels just the same as a Brushed Speed Control, giving you absolute control over the throttle with very smooth acceleration and the added bonus of longer run times when compared to Brushed Speed Control equivalents!
The 600can inrunner motor is 2100KV which equates to 2100 revs per volt (of your battery pack) for example, 24000rpm when run on a 12V battery.
Genesis Hydra50 features:
Easy one-step set up
Smooth controlable acceleration
5 to 10 cells NiCAD or NiMH
2-3 cells Lipo
6-12V Lead Acid
Automatic sensing of number and type of cells
Current limit cut-off
3A Hyper BEC
3 Internal Schottky diodes
Auto cut-off computer
Dimensions:-42mmx27mmx24mm
Weight:-60g
100% Waterproof
The Genesis Hydra50 speed control is capable of an average discharge rate of 45A and a peak discharge rate of 50A making it a very capable & attractive option at such a low price! Ideal for your first steps into the world of Brushless marine modelling!
The 'return to base' software upgrade enables the user to return their ESC to us to have the onboard software u
MikeA
« Reply #43 on: September 19, 2011, 11:14:47 am »
sounds pricey!! :} shame about your bad luck with the other motor. the motor cooling on that 3600 is cack anyway i had to redrill and fit new nipples to the cooling can cos the standard ones dont flow!!
Meyer
« Reply #44 on: September 27, 2011, 02:53:48 pm »
Hi ,
Well i have  a chat with Paul at Mtroniks, and so : I have now fitted the Feigao motor FG 5408490PL / 2887 Kv, going to run on their Hydro 50a controller, (I can also use this to run the 1200KV inrunner on the Ferrari Hydoplane) save some cash,javascript:void(0);
Meyer
« Reply #45 on: September 28, 2011, 02:31:53 pm »
Hi does any one know, where I can get a sound module, I heard Bernards, on this Bootlegger, it sounds fantasic, cheers for any info
Well sorry to drag this build on, !!!  while I'm waiting for the speed controller, and water cool fitting for the engine and cool plate , I'm  fitting the seats and dash, !!! and finishing off those little jobs,
MikeA
« Reply #46 on: September 28, 2011, 07:13:46 pm »
starting to come togeather, looking nice  :-))
Meyer
« Reply #47 on: September 28, 2011, 07:28:59 pm »
cheers Mike, thanks for your posts,
gwa84
« Reply #48 on: September 28, 2011, 08:29:23 pm »
looking sweet that lov the white strip in the planking realy pops with the varnish  :-))
Meyer
« Reply #49 on: September 28, 2011, 09:00:03 pm »
Hi, thants for your post, yes its starting to come together now, !!!
Pages: 1 [2] 3 4   Go Up
