Hello All.
A day off from building today, thought that I would set up the Tx and motors.
Have removed the ratchet from the throttle and made it sprung return to central, as the std elevator stick. This gives me independent control of each motor, including reverse.
Programmed the 2 speed controllers, ( very easy with the prog card ), and, after a little jiggling about with the program parameters have managed to get the motors to work in unison,
you can even hear the correct sound of twin motors in perfect synchronisation.
Rudders will be on the right hand stick alla Mode One ailerons.
The twin fans seem to work very well, so ESC cooling may not be a problem.
I am going to fit the 2 displaced 6v fans as extraction, venting from grilles below the cockpit rear seats,( all being well).
On a slightly different subject, can anyone tell me where to get a couple of lengths of 4mm tri stock mahogany abt 800mm long?
Or maybe some one out there could machine me some up
Mike.
