Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12   Go Down
Author Topic: My Build of H.M.T. RESOLVE from June 2011  (Read 108408 times)
wallace
Re: My Build of H.M.T. RESOLVE from June 2011
« Reply #125 on: May 18, 2012, 10:38:05 am »
Theses few pictures show the grey primer painted on down to the water line while looking at the grey primer on the hull by the boat deck was not to happy rub down after the photos were taken and filled ready to rub down the photos really help and show up everything.
                    wallace   :-)) :-))
« Reply #126 on: May 18, 2012, 02:30:23 pm »
Hi Wallace
Just thought I'd pop in and say hello  :-)
and I'm still watching your build progress.
Regards Dave
wallace
« Reply #127 on: May 19, 2012, 11:09:20 am »
Thanks Dave for taking the time to view my build its coming along at a very slow rate of knots,pleased with what I have done so far still along way to go.
              wallace    :-))
« Reply #128 on: May 19, 2012, 11:16:22 am »
Wallace - I like that it's a slow build.
Wham bam, thank You Mam' just doesn't float my boat {-)
(except at work - ooh I can't finish those shifts quick enough)
wallace
« Reply #129 on: May 26, 2012, 10:53:09 am »
More on the painting side added two more bits and coated in primer grey just abit more on the hull to get the water line spot on its the stern which I always have abit of touble but im getting there.
         wallace  :-)) :-))
« Reply #130 on: May 26, 2012, 10:57:09 am »
It's looking very nice Wallace.
To get the water line accurate, have you tried floating her in the bath  (correctly weighed down ) with Talcum powder in the water. When you carefully lift her out it will leave a line around the hull.   :}
ken
wallace
« Reply #131 on: May 28, 2012, 11:23:34 am »
Ken many thanks have never tried that way before always used my eyes and the plans but I will have a go.
Do you put the T- powder on top of the water before the boat goes in or the other way round.
      wallace
« Reply #132 on: May 28, 2012, 12:22:23 pm »
Hi Wallace,
Sprinkle it across the water top and immerse the boat gently. Lift it back out carefully and marks crucial points at intervals with a soft pencil.   :}
It's when it slips out of your hand and crashes into the water that causes much mirth.
ken
ken2
« Reply #133 on: May 28, 2012, 08:29:12 pm »
Hi Wallace
I just thought I might send you a picture of my Resolve.
A bit of a rush job compared to your progress and some features were guessed at and now need to be altered after futher research.
These were again taken by Tony Holt on our Droitwich Club Waters.
Hope it encourages your progress as it is a very interesting model to build.
I have also included an original for information
Ken2
wallace
« Reply #134 on: June 02, 2012, 11:27:45 am »
Looks good Ken2 to get it done in 3/4 months you must have been at it 24/7 im into my 12th month and still along way to go.
 wallace
ken2
« Reply #135 on: June 03, 2012, 03:38:00 pm »
Hi Wallace
Got to admit it was a lot of me time but I did have a heater in the workspace and cyno certainly solves a lot of problems.
At the end of the day its what suits as a life style and we are all different.
It now leaves a space to fill  -  What next ???
wallace
« Reply #136 on: July 15, 2012, 12:01:36 pm »
Back on track after a big break  have been doing abit but not had the time to post the build due to illness.
photos showing the capping rails  and how I have done them taped the rails to the plans and marked where the stantions are going then drilled with my small hand drill.I think Im going to stain the rails then varnish.
          wallace :-)) :-)) :-))
wallace
« Reply #137 on: July 15, 2012, 12:21:28 pm »
These are photos of the building of the wheelhouse and to be honest I built the wheelhouse two times as I didnt like the first one so took it apart and re-done as nothing matches the plans that I have but it done now and its looking good.
 wallace   :-)) :-))
wallace
« Reply #138 on: July 15, 2012, 12:37:33 pm »
More of the wheelhouse
         wallace  :-))
ken2
« Reply #139 on: July 17, 2012, 08:53:29 am »
Hi Wallace
So sorry to hear about illness but its a pleasure to see you back in action and reminding me of the problems and solutions you are going through.
I did find a slight problem of fit with the wheelhouse as you have to cut the veneer by hand and it can be a little brittle and fitting it to the CNC cut base needs a steady touch.
Good luck with the result
ken2
wallace
« Reply #140 on: July 19, 2012, 10:13:03 am »
More on the build of the wheelhouse I have made it my way and I think it looks alot better with the supports around the joins.
wallace
« Reply #141 on: July 20, 2012, 10:35:00 am »
At long last I have painted all the hull incluing the primer there is around 10 coats of paint and all hand painted which I always do.
« Reply #142 on: July 20, 2012, 10:38:53 am »
That looks superb Wallace.  What brushes do you use please as I'd like to get away from spray paint now and again. ?  Also, do you thin down the paint as ten coats sound a lot.
cheers
ken
« Reply #143 on: July 20, 2012, 12:14:24 pm »
Hi Wallace
looks lovely - yes any paint advice much appreciated.
wallace
« Reply #144 on: July 20, 2012, 05:39:55 pm »
Thanks for lovely reply to my build ie painting.
The brushes I use are sable brushes all are small headed from  1mm upto 10mm I painted the hull with the 10mm and the paint I use is all humbrol but the ships side is x royal navy paint ,I always rub down between coats and any bits I dont like a harder rub the wet and dry and sand paper goes upto 2000 so as I build up the coats the hight the grade of paper and I always leave coats on for min of 48 hours before another coat lightly rub then paint again.I never ever thin the paint down because I like a beautiful finish hope this helps one and all.
    wallace  :-)) :-))
« Reply #145 on: July 20, 2012, 05:59:19 pm »
cheers
ken
wallace
« Reply #146 on: July 22, 2012, 06:01:06 pm »
Ken and Dave here's all my battle gear for making my boats look nice ??? ha ha
you can see the brushes and make if you do close up's hope this helps.
        wallace  <*< <*<   :-) :-) O0
wallace
« Reply #147 on: July 22, 2012, 06:10:46 pm »
Here's the mid deck port and stbd companionway from the parts to putting together next will be the painting.
wallace
« Reply #148 on: September 04, 2012, 10:16:56 am »
   Here's the wheelhouse paneling all stained and ready to be put together.Also the printed decks all been stained.
       :-)) :-)) :-))    wallace
wallace
« Reply #149 on: September 09, 2012, 01:30:07 pm »
The wheelhouse paneling put together and fitted but not glue in place .
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12   Go Up
