Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12   Go Down
Author Topic: My Build of H.M.T. RESOLVE from June 2011  (Read 82260 times)
wallace
Re: My Build of H.M.T. RESOLVE from June 2011
« Reply #150 on: September 16, 2012, 02:19:52 pm »
More photo's about the panels around the wheelhouse.
    wallace  :-)) :-))
wallace
« Reply #151 on: September 16, 2012, 02:31:57 pm »
These photo's show the building of the    hatch's, companionways, salvage pump box,salvage pump gear box which is the bigger ones,water tank,
    wallace  :-)) :-))
wallace
« Reply #152 on: September 16, 2012, 02:37:43 pm »
more on the building
        wallace  :-))
wallace
« Reply #153 on: September 16, 2012, 02:51:50 pm »
More of the build for the upper deck.
      wallace  :-)) :-))
wallace
« Reply #154 on: September 16, 2012, 03:10:55 pm »
Now onto the funnel had to some cleaning up on the joins  and also had to put filler on and rub down.
I measured down from the top of the funnel 210mm and thats where the funnel base is position alot of fine rubbing down to get the base to fit.Holes had to be drilled for the funnel stay eyelets around the moulded funnel ring,holes also had to be drilled for the steam pipe,and the steam pipe is of alloy  had to be cut to 205mm and the top 10mm bent carefully to 10deg so far all are a pre=fit to see how it looks and before painting.
      wallace  :-)) :-)) :-))
wallace
« Reply #155 on: September 16, 2012, 03:15:25 pm »
more on the funnel.
 wallace  :-)) :-))
wallace
« Reply #156 on: September 16, 2012, 03:20:08 pm »
more off the funnel.
    wallace  :-))
wallace
« Reply #157 on: October 12, 2012, 11:50:38 am »
A few more of the funnel getting done had two coats of x navy grey paint and the tops painted in black also the inside of the funnels are painted in a matt black the steam pipes are not yet fixed into place as of yet will do when im happy with the paint.
« Reply #158 on: October 12, 2012, 12:33:19 pm »
Very nice Wallace, but , it might be an optical illusion , but do your funnels lean in opposite directions ?
wallace
« Reply #159 on: October 19, 2012, 04:34:36 pm »
Dicky here's your answer about the funnels not fixed in as of yet all my last posts have gone with the wind .
                  wallace  :-)) :-))
wallace
« Reply #160 on: October 19, 2012, 04:56:37 pm »
This is the gun platform getting built up as you can see alot of cutting and gluing  rubbing down then staining.
wallace
« Reply #161 on: October 19, 2012, 05:06:15 pm »
 Work on the stanchions and the wood railings the stanchions are of brass and 20mm two hole the top hole I sanded down to fit under the railing as I could not get one hole with pin so like we say there is always a way to do things and I done it my way
wallace
« Reply #162 on: October 19, 2012, 05:21:17 pm »
More on the Gun Platform all stained with two coats just need to varnish ,  and the first build of the gun to see how it looks not all done.
             wallace   :-)) :-))
wallace
« Reply #163 on: October 19, 2012, 05:25:19 pm »
More on the railing on the funnel deck as you can see had to do a very small railing the plans were not much good just hope it looks ok when all is done
         wallace  :-)) :-))
Stormbringer
« Reply #164 on: October 19, 2012, 07:02:59 pm »
certainly coming along nicely  :-))
wallace
« Reply #165 on: October 24, 2012, 11:19:19 am »
Here's more of the fitting of the brass stanchions and now with the brass wire just got to get a few more 20mm stanchion I missed counted (silly me )
           wallace  :-)) :-)) :-)) :-))
wallace
« Reply #166 on: October 24, 2012, 11:22:15 am »
A few more to have a look at
wallace
« Reply #167 on: October 25, 2012, 11:44:41 am »
Now back to the funnel these photos show how i fixed the funnel to the deck after making sure i got the height from the deck ok 210mm on both funnel I turn the deck up side down marked a line on both and then drilled a hole both sides to take a 2mm steel rod so it fixes under side and glued in place with epoxy and all around the funnel (have not had a look since and its now 24 hours so its well set) its my way of fixing so it does not come of down at the lake also I think its kids proof.
              wallace  :-)) :-))
wallace
« Reply #168 on: October 26, 2012, 12:09:34 pm »
Back once again to the gun platform have put brass stanchions in place of the white metal and also used brass wire,had to open up the hole to take the wire  as the photo shows very small drill all done by hand,the platform is in place but not fixed down got more to do.
wallace
« Reply #169 on: November 04, 2012, 11:12:28 am »
Back to the building after two weeks of this flu.
The photos today are how I'm putting together the Large and small Cowel vents.
I started by cutting two lengths of  70mm and two lengths of 45mm all from a 14mm piece of dowel,all four pieces had to be sanded for the bases and the top turn gear rings,the base has to go up the dowel around 5mm for it to fit into the deck,and the gear ring goes over the top of the dowel and sitting onto top of the gear ring is the cowl vents,the photos show the first part and none are glued together just put together to see how it looks.I will be drilling a hole in the top of the dowel and will epoxy a piece of wire rod also drill into the cowl vent and then join the two together with epoxy.There is other bits to put into place and the dowel has to be treated and painted will post when all is done.Hope you like   wallace  :-)) :-)) :-))
wallace
« Reply #170 on: November 04, 2012, 11:16:29 am »
A few more of the vent cowls.
wallace
« Reply #171 on: November 05, 2012, 04:54:07 pm »
Some more on the building of the cowl vents.
« Reply #172 on: November 17, 2012, 11:56:37 pm »
All of interest Wallace - enjoying your build very much.
wallace
« Reply #173 on: November 19, 2012, 11:41:56 am »
Still on the building of the cowl vents large and small these photo's show how bad the white metal is and it took me a few hours to rub them down to my standard. :-)) :-)) :-))
                    wallace
wallace
« Reply #174 on: November 19, 2012, 11:50:39 am »
Next stage of the building of the vents all have had primmer and top coat x two coats theses are the large vent which sit just behide the bridge and just high enough to get the air into the ship.  Please note the vents are not fully glued together as yet still need a bit of painting the inside of the vents will be painted black and the brass rod will be cut to size. :-)) :-))
                         wallace
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12   Go Up
Page created in 0.116 seconds with 21 queries.
