Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12   Go Down
Author Topic: My Build of H.M.T. RESOLVE from June 2011  (Read 104038 times)
wallace
Re: My Build of H.M.T. RESOLVE from June 2011
« Reply #225 on: April 27, 2013, 12:22:43 pm »
more on the build which takes me back to the bridge and wireless room Im doing the doors my way so they look the same in and out cutting the holes for the windows then I will stain them and varnish then when all dry will fix them in place then add the brass portholes.
                          wallace  :-)) :-))
wallace
« Reply #226 on: April 27, 2013, 12:26:32 pm »
more on the boat deck also the water tank that sits ontop of the wireless room have redone the pipe work so it goes down to the deck.
     wallace   :-)) :-))
« Reply #227 on: April 27, 2013, 04:16:59 pm »
It's looking good Wallace. :-))
Please keep the reports and photos
coming.
ken2
« Reply #228 on: May 07, 2013, 08:56:30 am »
Hi Wallace
You seem to be moving along well now.
A small point though with the water tanks. I have fitted a top fill and a bottom feed as per domestic practice.
You have fitted two bottom pipes as per the instructions. Was naval practice with these tanks different ?
I would be interested on any comments from anyone who knows.
Ken 2
wallace
« Reply #229 on: May 10, 2013, 12:23:56 pm »
More on the water tanks.
                 wallace  :-)) :-))
wallace
« Reply #230 on: May 10, 2013, 01:50:24 pm »
Doors for the wireless room.
                    wallace  :-)) :-))
wallace
« Reply #231 on: May 10, 2013, 01:55:50 pm »
more on the doors had to cut open to fit the plastic glass then join back together.
             wallace  :-)) :-))
wallace
« Reply #232 on: May 10, 2013, 01:58:35 pm »
doors all done put into place but not glue in just to have a look to see how they are.
                                   wallace  :-)) :-))
wallace
« Reply #233 on: May 10, 2013, 02:10:39 pm »
Onto the hatch's in the photo are  Hatch to Hold forward  Hatch to Hold aft both made out of wood
also two forward Coal hatch's and two aft Cargo hatch's  both are white metal as in early photos.
other photos are showing the hatch tops all made out of plywood  stained and varnihed.
                 wallace  :-)) :-))
wallace
« Reply #234 on: May 10, 2013, 02:15:37 pm »
more on the hatch's all together  and showing the base's are level so they sit level on the deck,with the cover's on which have all been sanded down to fit.
                             wallace  :-)) :-))
wallace
« Reply #235 on: May 10, 2013, 02:17:46 pm »
Photos
wallace
« Reply #236 on: May 10, 2013, 02:22:20 pm »
Hatch's and all the cover's are rub down and the base is had two coats of primmer and two coats of gloss and the covers are all stained and two coats of gloss varnish.
                              wallace  :-)) :-))
eddiesolo
« Reply #237 on: May 10, 2013, 03:13:44 pm »
Looking good, really good. I see you're a man after my own heart...using the a foam block for painting etc. :D
Si:)
wallace
« Reply #238 on: May 12, 2013, 02:45:19 pm »
Parts for the boat deck and also the Hatch's from top coat to the end product.
                            wallace  :-)) :-))
wallace
« Reply #239 on: May 18, 2013, 12:28:53 pm »
Wireless room on the boat deck all done and place but not fitted to the deck.
                          wallace  :-)) :-))
wallace
« Reply #240 on: May 18, 2013, 12:31:00 pm »
Getting the small air vents ready for painting.
                         wallace  :-)) :-))
wallace
« Reply #241 on: May 27, 2013, 02:42:54 pm »
Back to the funnel remove the unfix steam pipe and used nylon cord and lagged the both pipes from top to bottom I think it makes it look good.
                  Wallace  :-)) :-))
wallace
« Reply #242 on: August 27, 2013, 10:53:11 am »
Back on the build after a few months these photos are from May and the final bits of the funnel
                         wallace  :-)) :-))
wallace
« Reply #243 on: August 31, 2013, 01:22:42 pm »
Getting the davits ready but dont like the white metal (I think i will hunt online for some brass davits)
   wallace  :-)) :-))
wallace
« Reply #244 on: August 31, 2013, 01:30:57 pm »
still on the boat deck  the boat frames the the ships boats sit on are made out of ply 3mm and sit into a piece of wood for strengh the ships boats dont look right not happy with so found some great ones on dockyard so will be getting them.
            wallace  :-)) :-))
wallace
« Reply #245 on: September 01, 2013, 11:59:24 am »
Onto the stern platform made a few adjustments  to the drawing added a safely rail and cover the brass rail in nylon which makes it stand out.The photos were taken once again a few months ago getting the platform just right took a lot of hours but it looks good  when put all together.
             wallace  :-)) :-))
wallace
« Reply #246 on: September 01, 2013, 12:24:28 pm »
and more on the platform.
        wallace   :-)) :-))
wallace
« Reply #247 on: September 01, 2013, 12:26:52 pm »
These two photos are the fitting of the brass hand rail on the engin room cover.
     wallace  :-)) :-))
wallace
« Reply #248 on: September 01, 2013, 12:33:53 pm »
Sorry missed the other photo of the hand rail
                               wallace  :-)) :-))
wallace
« Reply #249 on: September 13, 2013, 10:39:08 am »
Photos of the building of the gun which sits on the f'wrd gun platform
                 wallace  :-)) :-))
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12   Go Up
Page created in 0.36 seconds with 16 queries.
