Pages: 1 2 3 [4] 5 6 7 8 9   Go Down
Author Topic: Mermod's - Tasmanian abeille liberty/bourbon build  (Read 57702 times)
Xtian29
Re: Mermod's - Tasmanian abeille liberty/bourbon build
« Reply #75 on: December 16, 2011, 12:33:11 pm »
Hello
Very nice work with the hull but may I say it's the simplest part of the model ?
Xtian
Jerry C
« Reply #76 on: January 24, 2012, 10:16:09 am »
Finally back onto the abeille, here is the nozzle and its support in mdf ready for casting, and the beginnings of the master for the rudder.
tassie48
« Reply #77 on: January 24, 2012, 10:06:24 pm »
seems like your normal fine work great to see you back into it keep going mate
Xtian29
« Reply #78 on: January 24, 2012, 10:38:29 pm »
Sorry for this out of subject comment but I was laughing so much with the Tassie48 "motto" never trust a captain that enjoys swimming
Have you nozzle pictures from other angles ?
Xtian
Jerry C
« Reply #79 on: January 24, 2012, 10:44:11 pm »
Hi xtian, I will take a couple more pics for you, I have found it really difficult to get shape of the supports for the nozzles but think i'm close, there is no detail for theese on any plan so im working from your photos.
Xtian29
« Reply #80 on: January 24, 2012, 10:50:12 pm »
I'm happy as I took these pictures specialy to help modellers like you  :-))
« Last Edit: January 24, 2012, 11:07:14 pm by xtian29 »
Jerry C
« Reply #81 on: January 25, 2012, 02:38:35 am »
a few more shots of the nozzle, rudder and support.
PeterS
« Reply #82 on: January 26, 2012, 05:12:22 am »
Hi Mermod
THX for "beeing your inspiration"  ok2  %)
This is a great hull!
A BIG one!
Thinking about my 1,6 m , your 1/40 must be a MONSTER !!!
As I can see, Xtian helped out with some pictures. Maybe I can help later with some details.
Peter
Jerry C
« Reply #83 on: January 26, 2012, 06:58:33 am »
Hi peter , love your build, think i'm going to need all the help I can get.
Jerry C
« Reply #84 on: January 29, 2012, 06:35:55 am »
just a bit more detail before moulding.The depth indicators are left proud and the background is laser engraved away.
Jerry C
« Reply #85 on: January 29, 2012, 06:38:00 am »
sprayed and test fitted once more before moulding.
Steve Mahoney
« Reply #86 on: January 31, 2012, 03:19:06 am »
Nice work on the depth indicators
Jerry C
« Reply #87 on: January 31, 2012, 07:01:47 am »
Thanks steve, it was tedious but fun
Jerry C
« Reply #88 on: February 07, 2012, 06:07:10 am »
Todays job was fitting the bow and stern thruster tubes, found some fibreglass tube I bought from a scrap yard about 8 years ago that had the perfect internal diameter.
Jerry C
« Reply #89 on: February 07, 2012, 06:09:53 am »
Here is the first set of resin castings for the rudder, nozzzle and its support ( ignore the grubby finger marks)
« Reply #90 on: February 07, 2012, 07:48:11 am »
Hi Mermod
I just want to say I have been watching your build and enjoying it.
It was only when I saw the hull next to the wheelie bin that I
realised just how big it is. Brilliant - can't wait for more.
Jerry C
« Reply #91 on: February 07, 2012, 07:56:04 am »
Thanks Dave, it's comments like yours that make the posts worthwhile, I'm still fairly new to the whole forum thing but its added a whole new dimension to my hobby, as for the size, the wife still thinks I'm mad but I cant wait to see four of them in the water.
« Reply #92 on: February 07, 2012, 08:13:21 am »
added a whole new dimension to my hobby.
Yep ............... and a case of wine is much nicer shared with friends  :-))
Plus all your hard work mightn't get the appreciation it deserves
otherwise. People see your finished product but not how you have
mastered techniques and found solutions. I'm learning from all the
builds ............ and from some of the arguements too - they provide
some options. Mayhem is generally a very friendly place to be. O0
Xtian29
« Reply #93 on: February 07, 2012, 01:16:09 pm »
Hello Mermod
Very good work as usual. You used teh same diameter for the bow and aft transverse thruster ?
Have you seen there is now Algerian navy sister ships !
http://inverclydenow.com/news/pictures/ships-boats-and-maritime-images/tugs/other-tugs/el-moundjid-11385
Xtian
boatmadman
« Reply #94 on: February 07, 2012, 01:32:25 pm »
Thats looking really good, keep up the good work.
Ian
Jerry C
« Reply #95 on: February 11, 2012, 10:42:27 pm »
Thanks for the comments Ian.
Xtian, would you believe we discussed the fact that the bow thruters were larger when the build started but I clearly got carried away and made them all the same size, thanks for picking up on that, it's now been fixed, only wish i'd read your post before glassing them in, oh well nothing an angle grinder won't fix.
I now tell people that my quality controll team is based in france, you should see the looks I get!
please dont ever hesitate to point out mistakes like that, thanks
Jerry C
« Reply #96 on: February 12, 2012, 01:42:20 am »
Bilge keels cut from 1.5mm brass, no details for these on the plan so i've had to wing it using the photos from Xtian , I find that you can follow the weld lines on the full size hull to approximate where things should go, also does anyone know what the two openings are on the starboard side just above the fromt of the bilge keel ?
Xtian29
« Reply #97 on: February 12, 2012, 03:38:36 am »
Hello
Quality Control ... ok it's fine for me and for this ship   {-)
The two grids just over the starboard bilge keel are for seawater inflow : some onboard users like fire fighting or fresh water producer.
Inside the hull there is a tranquilized box and the "users" pick a tubing on it  - you can see the size of the box with the air outlets and water oulets ( used when the ship is drydocked to remove the rest of water inside the box and then when the ship come back to water, the air come out from this box via the upper holes)
There is another seawater inlet on the starboard keel.
Xtian
tassie48
« Reply #98 on: February 12, 2012, 05:34:58 am »
mermod luv the 1-1 scale photos for reference thats great reference material haha looking good old mate keep up the great work looking forward to getting mine tassie48
Jerry C
« Reply #99 on: February 12, 2012, 07:34:42 am »
Hi Tassie48, you'll have to run your eye over it when you get down here, I'm casting multiples of everything so there will be plenty of bits.
Thanks Xtian for gettting back about the vents so quick, means I could get straight into it, using your photos I made a drawing in CAD then laser angraved the grate detail in some acrylic.
Pages: 1 2 3 [4] 5 6 7 8 9   Go Up
