Author Topic: Pins Nails and Planking  (Read 2350 times)
ukmike
« on: August 10, 2011, 07:12:34 pm »
Please help.
If when planking a model boat hull nails or pins are used, then how are the holes hidden when the nails/pins are removed?
I am building model that is planked in Mahogany with no holes shown.
Do I just wet the finished hull to expand the timber ?
Mike.
Re: Pins Nails and Planking
« Reply #1 on: August 10, 2011, 07:36:31 pm »
Maybe use a quick grab glue like Deluxe materials Super Phatic or similar and use tape to keep the plank in place while it sets. No holes then.
« Reply #2 on: August 11, 2011, 05:24:57 am »
Very hard to hide holes.
One possible answer is to mix the mahogany saw dust with glue to fill the hole, but you will never get a perfect color match.
Gluing without pins is the way to go, as Colin suggests.
ukmike
« Reply #3 on: August 15, 2011, 06:11:18 pm »
Seem to have solved the problem.
Pinned an offcut of the planking mahogany using 0.8mm pins and the Amati pin pusher half a dozen times, then, removed the pins
and wet the planks, hey presto, wood swelled and completely removed the pin holes.
Joy.
Mike.
Page created in 0.415 seconds with 21 queries.
