i am consdering useing lipo's but i know little about them. i need some help with them please.
1, if im to use lipo whats the best way to get 14.8 volt that will fit in my boat. should i run 2 saddle 7.4's or a single 4s battery.
It depends on how much room you have - not a lot go with the 2 x 2S saddle packs in series or a single 4s, if you have plenty of room then you can also saddle up 2 x 4S in parallel for better duration.
2, i gather i need a low voltage cut off. usually with nimh if the batteries are gettin low the boat slows down and you know to bring it back in. But if lipos just cut off as before it slows down does that mean my boat is stuck out in the middle of the lake? what warning have i got?
Most esc's have the facility that when LVC cuts in you can reset the esc, (by going to low throttle), to allow 'main' power back, (at a reduced setting), to recover the model.
[/quote]3, wont 2 8.4's running 16.8 be faster than a 4s anyway? albeit heavier though
Hmmm, a fully charged 4S is at 16.8v and should hold a higher voltage, i.e. over 14.4v, under load better than the 14 cell NiMH pack, which will be starting at around 21v 'hot off the charger' stabilising at around 18-19v about 30 mins after charging, but will drop quicker than the LiPo under load. ** comparing like for like capacity packs **
Mark.
