After testing the boat on the water last week I have finally managed to actually get some bits painted. The problem with doing a conversion from a static model like this to an R/C version is that you have to plan the build in a different way from that specified in the kit instructions, this means some of the painting and detailing that you would do at the beginning of the build can only be carried out toward the end.
After testing the boat and seeing just how fast it's going to be I have decided to run it on the water with only the centre propshaft and prop. I will fit dummy shafts and props when I take the boat to exhibitions - at least it will give me some running equipment for the S-Boat and the Vosper (when it's released).
Our Boat club Chairman is also currently building PT596 as an RC conversion. He is building his as per the kit from the box. Not wanting to have two identical boats in the club I had made the decision to build mine as one the RON29 boats. This was the ELCO squadron that served in the Mediterranean, to further complicate things I am going to build the boat as one of the four from this squadron that carried the Thunderbolt gun system. This will be scratchbuilt. However this means that the colour scheme will be Thayer blue for the Hull and other vertical surfaces and Deck blue for the deck etc. I have had to mix my own paint using a chip colour I found on this site
http://www.steelnavy.com/usnchips.htm. This is modified Measures 16 (according to John Lambert's Coastal forces book).
So here are the photos of progress so far. One is the Hull after spraying, together with the exhaust mufflers, gun turret components and shots of the deck and cabin. The keen eyed of you may notice that the smoke cannister is at the rear of the deck rather than along the side of it - this is because on the RON 29 boats the torpedoes were set further back and the cannister repositioned.
Finally if anyone is interested I have been using Revell Aqua Acrylics to paint with - I am gradually changing to these from Humbrol enamels - I water them down with distilled water and they seem to spray really well at around 30psi.. That's it for today.
