I dont bother with all the bodyfiller route of doing it, too much work sanding it all down, and the mess, and extra weight, and you have to be quite good at it to get a good result. I use very light cloth as mentioned earlier from deluxe materials, I think its 5g weight, the lightest stuff, use a coat of resin, which is only wafer thin applied with a piece of plastic card, get the cloth on it before it goes off, and the another thin coat of resin. This seals the wood, and is a rock hard finish when cured so if you hit something (like the side of the lake
) it wont crack or fall off!)
Sand it flat with something like 80 grit paper using a block, relatively easy as you can visually see the high spots, then prime and usual paint process. This process also stops the wood delaminating over time. Personnally, I dont like sealing the inside and outside, so just use a clear satin varnish applied with cloth on the inside, I believe the wood has to breathe, so if its sealed on the outside, the inside does not need doing, in my opinion. Everyone has their own preference, thsi is mine
Funnily enough, been doing it tonight
First pic shows cloth prior to rubbing down, second its now rubbed down using block and 80 grit, nwext step another coat of resin, rub down, with 80 grit, then work with 100 for priming stage, then its the hard work, finishing with 1000 grit wet and dry to achieve a mirror flat finish
Hard work, but the preparation makes the job
