Author Topic: 12v to 6volt reduction  (Read 1618 times)
Cornishman
« on: August 25, 2011, 12:26:49 pm »
I am building a boat which I have to run the motor on 12 volts. However I also have a bow thruster which I need to run at 6 volts. I could wire two 6 volt batteries in series and take a centre tapping to give me a 6 volt supply, or install  one 6 volt and one 12 volt battery and use two separate supplies, But is there a better way I can do this possibly electronically?
Can anyone help?
john s 2
Re: 12v to 6volt reduction
« Reply #1 on: August 25, 2011, 01:06:47 pm »
A centre tap would be fine or as you say a 12v and 6v battery Could be better depending on space and weight. John.
« Reply #2 on: August 25, 2011, 05:21:18 pm »
Since the thruster will probably be used intermittently, the center tap should be fine.  Either that or a separate battery.  Trying to do it electronically, at the current required, would result in an electronic lump about the same size.
dreadnought72
« Reply #3 on: August 25, 2011, 06:48:18 pm »
What's the max amps of the bow thruster? Because, as I found out in the Racundra thread, there's a cheap(ish) way to get 6V out of a 12V stone if <5A is ok.
Andy
Cornishman
« Reply #4 on: August 25, 2011, 07:26:43 pm »
It is the Graupner 1785 thruster with a Speed 400 motor quoted at 4 amps at max efficiency
dreadnought72
« Reply #5 on: August 25, 2011, 09:31:49 pm »
Hmmm...then the regulator I mentioned would seem to be ok.
It contains an LM338T (a guess, but based on some reading about the subject) and a few components to lower a 12V source to 6V output, and is capable of outputting 5A. If the bow thruster is going to run for short periods now and again, I can't see this regulator melting. Might be worth a punt since it's only a tenner?
Andy
cos918
« Reply #6 on: August 26, 2011, 05:31:37 am »
There is this
http://www.harbormodels.com/site08/main_pages/power_distribution_panel.htm
But a 6V battery would be cheaper.
Timo2
« Reply #7 on: August 26, 2011, 07:52:04 am »
Hi Cornishman
    I have a PM
 Timo2
