Author Topic: Prop preference  (Read 6031 times)
tt1
Prop preference
« on: August 30, 2011, 04:39:49 pm »
Hello folks can anyone please help with opinion of which may be the better props choosing between Raboesch or Rivabo?
                            ( I am aware Prop Shop are infamous for their quality)
                                            Regards, Tony.
andyn
Re: Prop preference
« Reply #1 on: August 30, 2011, 04:50:38 pm »
No real difference really, Rivabo seems to be a wee bit cheaper but Raboesch has more range to choose from. Take your pick :-)
tt1
Re: Prop preference
« Reply #2 on: August 30, 2011, 04:53:19 pm »
Thanks Andy.
Re: Prop preference
« Reply #3 on: August 30, 2011, 10:30:11 pm »
I've always used Raboesch on my boats and they are fine.
Give me a ring on Skype sometime please Tony  :-))
tt1
Re: Prop preference
« Reply #4 on: August 31, 2011, 12:53:39 am »
 Thanks Richard - will do  :-))
irishcarguy
Re: Prop preference
« Reply #5 on: September 01, 2011, 09:10:00 pm »
Being new to the forum & also to model boat building I too would like to learn more about props & motor & prop combinations. Is there anywhere on the forum or anywhere for that matter where a newbie like me could find that kind of information in a reasonably condensed packet bearing in mind most people have their own preferences. That sure would be  a big help to dumb & dumber (me). I can see where a lot of members are always trying different props & motor combinations, which could get expensive in hurry, I hope someone can at least help a little bit. ( I have for instance noticed that you use a special prop for use in kort nozzles, am I correct ??) Mick B.
Mick B.
john44
Re: Prop preference
« Reply #6 on: September 01, 2011, 09:33:09 pm »
Hi MickB, if you go to the Cornwall model boats website and open the links to propellers it gives you the various types
and the application for the numerous propellers model boaters use.
john
irishcarguy
Re: Prop preference
« Reply #7 on: September 01, 2011, 09:40:40 pm »
Thanks John, I have dealt with Martin & cornwall, nice fellow,but the props I asked for I did not get, so that led me to ask the question about props in general.
Mick B.
Re: Prop preference
« Reply #8 on: September 01, 2011, 09:43:09 pm »
Hi Mick
Yes, you are correct. The Kort propellers have a more flattened tip to rotate inside the Kort drum.
regards
ken
miklav
Re: Prop preference
« Reply #9 on: September 07, 2011, 09:01:05 pm »
Could you please elaborate on that? I've just read in another forum that Prop Shop is considered to be a "gold standard" above Raboesch and Rivabo.
(I am thinking about the right propellers for the boat that is at the beginning stage of the build)
Re: Prop preference
« Reply #10 on: September 07, 2011, 11:17:55 pm »
Prop Shop props are cast, profiled and finished like the real size props.
The other props have almost flat brass sheet for blades.
philk
Re: Prop preference
« Reply #11 on: September 07, 2011, 11:19:34 pm »
he probably should have put famous
phil
tt1
Re: Prop preference
« Reply #12 on: September 08, 2011, 12:49:36 am »
Sorry miklav! - quite right Phil should read famous - doh!
                                 Tony.
Re: Prop preference
« Reply #13 on: September 08, 2011, 06:03:07 am »
Its actually Malcolm not Martin. :-))
miklav
Re: Prop preference
« Reply #14 on: September 08, 2011, 06:31:31 am »
thank you - that's what I thought :)
Currently the prop shop propellers is my tentative selection for my scale speedboat not only because of quality but also a higher pitch compared to props from Rabousch.
Where can I find tech specs for Rivabo props? I mean pitch and max rpm (for ~40mm diameter 3-blades).
john44
Re: Prop preference
« Reply #15 on: September 09, 2011, 08:08:16 pm »
Hi miklav, the information you are looking for is on www.cornwallmodelboats.co.uk
Rivarbo 40mm 3blade props  = part No  534040
regards
john
tt1
Re: Prop preference
« Reply #16 on: September 10, 2011, 01:18:55 am »
Just a point of note,  I ordered Raboesch but ended up with different props, Caldercraft!? - are they as good?
                             regards, Tony
HS93 (RIP)
  • I cannot spell , tough
Re: Prop preference
« Reply #17 on: September 10, 2011, 01:31:52 am »
I thnk you may find if you ring them it is a  Rabousch as they are now the Uk agents
Peter
tt1
Re: Prop preference
« Reply #18 on: September 10, 2011, 01:40:16 am »
Thanks Peter  :-))
                   Regards, Tony.
P.S. ----- good morning! off to bed now and Dean's open day later! cheers.
irishcarguy
Re: Prop preference
« Reply #19 on: September 19, 2011, 07:42:42 am »
What I meant to say DickyD was Martin @ Westbourne & Malcolm @ Cornwall (also Sam @ Cornwall) Nice people to deal with, I am at present waiting some bits from Westbourne.I have had good service from both companies, but ACTion wins hands down, I don't know how Dave does it but don't stop. Mick B.
Mick B.
