Using Epoxy resin, do as John suggested, however, I would use the epoxy to glue it all together, and seal the whole hull with epoxy, inside and out as you go, tissuing only the outside surface. This will seal the wood and it should outlast all of us.
Can't do this with Polyester as its not vapour proof, is water soluble and is why the use of gell coat to seal is required.
cheers
kiwi
