Details now on Mtroniks website: http://www.mtroniks.net/details1.asp/ProductID/733/digisound5m.htmThe digiSOUND5m is the new marine sound module from Mtroniks Ltd. It is the worlds first 100% waterproof, plug n play sound module designed to take the hassle out of giving your model a realistic sound! The sound module requires NO programming or set up, it comes with a realistic sound pre-installed leaving just the installation to complete before you can get under way! The unit comes complete with built in amplifier, wiring loom and even a 75.0mm diameter waterproof speaker!
You simply install the unit in your model and go! There is no complicated PC interface to deal with or complicated set up, you REALLY do just have to plug it in and go!!! Add this to the legendary Mtroniks waterproof construction and you really don't need to look any further!
The digiSOUND sound module for model boats will operate between 6.0 and 12.0V
This first version of the digiSOUND5m is available with a Diesel tug sound effect, more sounds will become available over time, please keep an eye on our webpage for further updates!
Currently available sounds: Diesel Tug
Detailed specification of module and speaker
Module power output: 5 Watts RMS @ 12V (4 ohms), distortion typically 0.1%
Speaker rating: 2.5 Watts RMS (8 ohms), It is possible to run 2 speakers in parallel
Notes on speaker performance.
The 75.0mm speaker included with your module is waterproof so it is safe to use in your model boat, you should always install your speaker into a suitable enclosure (somewhere in the upper surface of the hull) to ensure the best power handling, frequency and bass response.
Speaker systems with a broader frequency response which include tweeters and larger woofers are available as optional extras, please contact Mtroniks for details.
