Author Topic: MMM Rosgarth - info please.  (Read 2087 times)
barriew
« on: March 15, 2007, 04:20:36 pm »
I am building MMM's Rosegarth. I collected the fittings last weekend and am now trying to work out which way to fit the Rope Hawsers - see picture. Does Part A or Part B go inboard?
Barrie
BlazingPenguin
Re: MMM Rosgarth - info please.
« Reply #1 on: March 15, 2007, 05:07:37 pm »
Part 'A' goes outboard, is trimmed to fit thickness of hull + thickness of washer. Washer glued on after!
barriew
« Reply #2 on: March 15, 2007, 05:48:22 pm »
Thanks - wasn't quite sure.
Barrie
andywright
    • Windpowersails
« Reply #3 on: March 15, 2007, 08:48:55 pm »
Part  'B' goes outboard, honestly, I am a tug skipper. sometimes on more modern tugs with the more power to size ratio there are  four webs on part 'A'  at 6  and 12 o clock and at 3 and 9 o clock to the tugs bulwarks for strength. Don't put 'A' on the outside it will catch abnd snag on every thing the tug goes along side.
Regards Andy
« Last Edit: March 15, 2007, 08:52:39 pm by andywright »
Peranos
« Reply #4 on: March 15, 2007, 10:45:46 pm »
 :( You're both wrong. Part A is fitted from the inside and part B is fitted over the bit of part A that protrudes through the hull on the outside. When part A is trimmed flush with part B, there is a nice smooth profile on the bow that nothing can be damaged by or caught up on.
John P.  :)
norry
« Reply #5 on: March 16, 2007, 07:32:16 am »
A goes Inside...B slips over the outside edge of A and  A is  then filed down flush to make nice ring on the outside...
If Fitted the other way round It will catch on everything the tug goes alongside...
I,ve built a few of Brians boats...
You can see one in place on the port aft bulwark of this tug...
« Last Edit: March 16, 2007, 07:37:09 am by norry »
barriew
« Reply #6 on: March 16, 2007, 10:05:23 am »
OK, the consensus is that A goes inside. Its difficult to see black on black, but Norry's picture makes it clear.
Thanks,
Barrie
BlazingPenguin
« Reply #7 on: March 16, 2007, 10:50:24 am »
the leg bones connected to the...hip bone...the hip bones connected to the...neck bone..the neck bones....Oh build it yourself? ???
