Hi All,
I'm in the process of building my 1st model boat ! A Fairey Huntsman 34". I thought I will make it a bit easier on myself and bought a kit with a fibreglass hull. I built myself a stand for it and I'm now ready to start
The last picture show where i am with the hull frames. More to follow as i progress....
I haven't yet decided on the motor/esc/batteries, but one thought was this Overlander Brushless motor which is a T4250/06 800kv, a reasonable size motor which should have lots of torque but would it have enough RPM at only 800kv (with a 14.8v lipo it will give me 800*14.8=11840 rpm) ?
I have a 3 blade 40mm prop on a 4mm shaft at the moment, I guess i want the ability to turn a reasonable amount of speed.
http://www.overlander.co.uk/tornado-thumper-v2-4250-06-800kv-motor-949.htmlsome other motors Overlander do are:
SeriesMotor Kv Watts Winds Esc Cells Propellors Weight Shaft
V2 T2226/25 1800 115 25 10 2 - 4 8 x 4 21g saver
V2 T2230/15 1780 125 15 15 2 - 4 8 x 4 27g saver
V2 T2826/09 1900 260 9 18 2 - 4 from 7" 50g 3.2mm
V2 T2826/14 1200 235 14 18 2 - 4 from 8" 50g 3.2mm
V2 T2836/8 1120 290 8 20 2 - 4 from 8" 67g 4mm
V2 T3536/5 1450 650 5 40 2 - 4 from 8" 110g 4mm
V2 T3536/8 1000 480 8 40 2 - 4 from 9.5" 110g 4mm
V2 T3548/5 900 770 5 60 2 - 4 from 9" 155g 4mm
V2 T4240/10 890 650 10 60 3 - 7 from 13" 140g 5mm
V2 T4250/6 800 1010 6 60 3 - 7 from 13" 210g 5mm
V2 T4260/6 500 1375 6 60 3 - 7 from 15" 280g 5mm
V2 T5045/10 720 1250 10 80 3 - 8 from 13" 210g 8mm
p.s fantastic forum so much information
Chris
