Author Topic: battery help please  (Read 3672 times)
martinbrewster
battery help please
« on: September 12, 2011, 08:23:00 pm »
i have two7.2 3300mln batterys that i would like to conett together to run a 12 vol speed 600 is this possible? if so what size speed controller would you say is needed thank you martin
Re: battery help please
« Reply #1 on: September 12, 2011, 08:43:44 pm »
If you connect two 7.2v batteries together you end up with either a 7.2v 6600mAh battery or a 14.4v 3300mAh battery.  :-))
justboatonic
« Reply #2 on: September 12, 2011, 10:00:24 pm »
Some esc's dont like two batteries in series so check before you buy. I dont know any esc's that wont work with two batteries in parallel.
« Reply #3 on: September 13, 2011, 09:51:31 am »
In parallel, the motor will run in a calm and dignified manner.  In series, it will be nudging the safety margin built into its specification, and will need either a smaller prop or water cooling or both.
An ESC that is rated as "12 volt" by its maker is intended for a 12 volt SLA, and so is, or should be, good for the 14 and a bit that a fully charged one will deliver.  I would look very closely at the specifications if fitting a battery arrangement that was going to deliver nearer 17 volts when charged.  Maybe have a look at other threads in the forum.
martinbrewster
« Reply #4 on: September 13, 2011, 09:07:34 pm »
thanks for your help which would be better or last longer a 7.2 3300ml or a 12 vol 1.2 bearing in mind a12volt moter thank you martin
« Reply #5 on: September 14, 2011, 09:37:47 am »
The bigger capacity (in this case, the 7.2volt) will last longer.  Because its a lower voltage, it will also probably seem much, much longer.
Harquebus
« Reply #6 on: August 19, 2012, 03:27:35 pm »
I find it interesting the differences between series and parallel wiring in motors and batteries:
PARALLEL MOTORS
Pros - Max power, high top speed
Cons - Half the run time of a single motor setup or dual motors in series, high amp draw needing heavy duty ESC
PARALLEL BATTERIES
Pros - Long run time, easy on electrics
Cons - Heavy
SERIES MOTORS
Pros - Long run time, lots of torque
Cons - Low top speed
SERIES BATTERIES
Pros - Explosive power
Cons - Heavy, requires heavy duty ESC
What happens with parallel motors on series batteries? I am but a novice...
~Harq
« Reply #7 on: August 20, 2012, 10:09:13 am »
Each motor behaves as if it was on the higher voltage, i.e. it tries to spin a lot faster.  It also draws more current.  Two of them draw twice the current, so the ability of the battery to supply the current and the wiring and ESC to carry said current becomes an important limiting factor.
SERIES MOTORS
Not necessarily lots of torque.  That depends on the design of the motor.  Generally, more poles = more torque but less speed.
Power is a function of amps through the turns times the number of turns, but the more turns in a given space, the thinner the wire and thus fewer amps.  To get more power with a large number of thin wire turns requires higher voltage.
