Thanks for the comments and pictures, all pics are always appreciated!
I am not 100% sure "IF" the missing items are from the model hull design mould and "could" of been moulded upon the "early" hull profile, i;m unsure on that, but being as I'm trying to model 12-26, barmouth Lifeboat, suppose that puts me in the "later class" [ha ha].
Anyway, onwards and a little upwards. After much discussion over the past couple of days, the "what motor" issue is still simmering, as the "supplied propellers" at 55mm were recommended for brushless motors and not "brushed" as I have found out. So I now have 2 options if I wish to remain with good old ever faithful brushed. I fit 700 bb turbo's and go for smaller 45mm props, or go 900 motors and fit 50mm jobby's. Graupner 900's and not in stock anywhere in the Uk or Europe, believe mem, ive tried, even graupner cannot give a delivery date. But, Andy at Models By design recommened an ebay seller who can supply 900 type motors at a much cheaper rate and has stock too!, so this coupled with a pair of 12v nicad sticks will become my powerplant!
Action Electronics have already supplied all the necessary drive gear, so this is the way I will go.
Due to the "tunnel prop" design, I have also been strongly recommended to "tank steer" with the motors as the rudders [apparently] are as muich use as a chocolate teapot, even on the full size brutes. Fortunately the Action P94 does have a program suitable for this", so will maybe give it a try, but I will be linking the rudders up to a servo "as well as", not wanting to give up too soon on a job.
Right. Todays little skirmish with the lifeboat. Ive cut out the 3 forward hatch cover panels and inserted a "edge liner" to act as the waterproof lip/hatch edge. I firstly marked out the hatch positions, then for "ease" found a 5p piece gives a nice radius to the corners. I then followed by cutting out the corners with a 20mm drill cutter, I used one i was given free with a set of reversing sensors for my car bumper, so yes, some things do come in handy for all sorts of jobs!
I then cut some strips 10mm deep out of 0.5mm plasticard to act as the coaming edges, these were temporarily held in place with a few drops of superglue, then bonded in with stabilit express to fully fix in place. Once this is fully dry, i can then sand the top [pouter] lip edge flat, to take the hatch covers at a later stage in the build.
this now also allows me to make up some square locker boxes to attach from the underside, to go under these covers. What i will do however, is fit out one with its stock of ropes etc, the other 2 will contain switch panels for ease of operation of the boat, once at poolside. I will use 2 hatches for the switches, it saves my elephants paws from hitting too many switches at once !!!
